Getting a Parameter value from file as string
machiel.veldkamp
machiel.veldkamp
Hi!
I have this:
	Dim oModel As PartDocument
	FilePath = "C:\Relco\Vault\Designs\USERS EU\MACHIEL VELDKAMP\BulkDrawingToolParam.ipt"
	oModel = ThisApplication.Documents.Open(FilePath, False)
	auto = iLogicVb.Automation
	auto.RunRule(oModel, "Show Form") 'in the model there is a rule called "Show Form" that changes some parameters
	ILOGIC_PRINT = Parameter(<What should I put here?>, "ILOGIC_PRINT")
I want the ILOGIC_PRINT to contain the value that is currently in the model.
Now. I thought this would be easy but I can't figure it out.
If I put FilePath or oModel in the Parameter field It returns an error saying that that it's not an object.
___________________________
machiel.veldkamp
	oModel = ThisApplication.Documents.Open(FilePath, TRUE)
	Test = oModel.FullDocumentName
	Dim ILOGIC_PRINT As String
	ILOGIC_PRINT = Parameter(Test, "ILOGIC_PRINT")
	MessageBox.Show(ILOGIC_PRINT, "Title")
This returns:
Parameter: The document named "C:\Relco\Vault\Designs\USERS EU\MACHIEL VELDKAMP\BulkDrawingToolParam.ipt" was not found.
That is so strange because 2ms before I open that document.
What is happening?
Sergio.D.Suárez
Hi, try with this rule.
Keep in mind to close the document at the end of your rule, because you have opened the document in hidden mode first.
	IlogicPrint = oModel.ComponentDefinition.Parameters("ILOGIC_PRINT").Value
	'oModel.Close
 I hope the rule works for you. Grettings
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
machiel.veldkamp
Ah brilliant.
Thanks a lot!
