Custom iLogic trigger
I know of and use the standard event triggers built into Inventor (Open, Close, Save, etc.).  What I need to do now is have an iLogic rule run whenever the "Finish Sketch" button is pressed.  Is there a way to create custom event triggers in Inventor?
johnsonshiue
Hi! I am not sure if you could customize a trigger programmatically after Finish Sketch. It may be doable. Or, you can use iTrigger to run the rule.
Many thanks!
Software Test Engineer
bradeneuropeArthur
In illogic this is very complicated.
In vb.net it is easy to do....
let me know what you need
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
I have an iLogic rule written and working, but I would like it to run after a sketch is closed as opposed to any of the built in options (Save, Close, Open, etc.).
bradeneuropeArthur
Yes that is the difficult in I logic. By for vb.net no problem. Please let me know what you prefer to do....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
