Custom file templates are reset to default
Using Inventor 2013 (2014, same behavior), I've customized our part, assembly and drawing templates with the original names (i.e. Standard.ipt, ...) and put them in a network shared folder.
I've created an Application Options file to use the same options and placed it also in a network shared folder.
As soon as I "Import" this Application Options file, the shared templates are reset to the Autodesk Standard Templates (Standard.ipt = 05/03/2012), in the shared folder.
A solution could have been to use custom names, but the users cannot use the scroll list when creating a new file. This scroll list searches for "Standard" named files only. And the standard files will reappear too, which will be confusing !
Have a solution ?
MechMachineMan
What scroll list are you talking about?
This is a know issue, and yes, you just have to use a custom named file ie; Standard [COMPANY NAME].ipt AND/OR put them in a sub-folder of actual templates to use.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
The scroll list I was speaking about is the one under the arrow near the NEW button in the Quick Access Toolbar.
Thank you Justin, for having confirmed what I was afraid of : "known problem" !
