Custom add-in: Store user preferences
DRoam
Mentor Mentor
Message 1 of 8
DRoam
I can build a UI for specifying user preferences easily enough -- but what's the best way to store those so they persist from session to session? Can I have my add-in create an XML file for these? If so, where should said file be stored?
Replies (7)
Message 2 of 8
HermJan.Otterman
If you build an addin, then you could read from and write to the windows registry...
https://docs.microsoft.com/en-us/dotnet/visual-basic/developing-apps/programming/computer-resources/...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 8
bradeneuropeArthur
use the setting of the add in
add a setting like Setting001 as boolean = true
then use this in your code
My.Settings.Setting001 = false ' or true
My.Settings.save
this will store the settings in the inventor XML file
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 8
DRoam
Hmm, that could work. Is that pretty safe to do as long as I'm staying inside my own custom key/folder? I would assume if I create my own key, say under "Computer\HKEY_CURRENT_USER\Software\<MyAddinName>", I don't need to worry about corrupting Windows or other applications. Is that correct?
Message 5 of 8
HermJan.Otterman
in visual studio you also have, under the application properties Settings.
here you also can store things
https://docs.microsoft.com/en-us/previous-versions/cftf714c(v=vs.100)
Herm Jan
Message 6 of 8
HermJan.Otterman
yes you can do that.
If you write an application for other people you could get some trouble with rights if they are limited
I used Hkey_currernt_User
Herm Jan
Message 7 of 8
bradeneuropeArthur
My mandatory or default settings are always loaded on loading the add in.
But before I do that I check if they exist and than only write them if they are not there.
So only when the user first starts the add in otherwise I don't write them.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
DRoam
So there is a built-in settings mechanism in Visual Studio, that's really neat. Any advantages to using the registry over this?
Can you explain what you mean by this? How do you "check if they exist"? Exist where?
What do you mean you "don't write them" unless it's the first start? Aren't they already written in the app.config file at compile-time?
Thanks again for the help.
