Creating a .addin file as per DevTools Sample
MechMachineMan
Advisor Advisor
MechMachineMan
So in deciding to make an add-in, I was browsing through some samples. It seems this one is pretty much exactly what I need. (I want to create a simple add in to run a class module every time inventor loads so that I can use macros to track file saves using events.)
D:\Program Files\Autodesk\DevTools\DeveloperTools\Samples\VB.NET\AddIns\VBAAutoMacros
In the steps in the readme, it says to create a .addin file and move some files around. I created a .txt file and renamed it to .addin and followed the rest of the instructions, but it does not load on Inventor startup.
Is there something I'm doing wrong here?
Thanks.
Attached is the read-me with the instructions I followed.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan
Never mind. Got it figured. Think it was just a restart to fix it since I had just installed Visual Express 2012 on the same boot.
These built in add-ins seem pretty awesome!
Had noticed one for revision clouds too, which seems pretty awesome.
Justin K
@MechMachineMan This is not working for me. I've followed the readme step by step and restarted by PC. Do I need to be on IV2017 or greater?
I'm using IV2015 but the readme file that comes with my SDK looks the same as yours.
