Create Viewing by VBA
Message 1 of 20
please take some consideration for me, because I am not a programmer.
I want to create a VBA code to create a drawing view.
Drawing with sheet is done and view insert with front and standard.
What I need:
- Change the view to backside
- Change the type of view from standard to a view called "machine"
- Change Position of the View to the bottemleft corner
- Set scale to 1:1
And thats for every sheet with the name "Machine".
Where can I finde information for the points? Easy to understand. 😉
Maybe someone can help with a code?
Thx for your help!
Replies (19)
Message 2 of 20
As I managed to do the other codes in iLogic, how can I rotate a View (change camera to backside, left, right, bottom, top)?
Message 3 of 20
HermJan.Otterman
look in the help of inventor for Programming/Api help.
there are VBA examples on how to create views on a sheet
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 4 of 20
Ok. Got it.
Exept one point. 😞
In iLogic its simple:
ActiveSheet.View(View).SetSpacingToCorner(0, 0, SheetCorner.BottomLeft)
Where can I find information how to set the view to the bottomleft corner via VBA?
A direkt link, keyword or example would be helpfull.
Message 5 of 20
HermJan.Otterman
here is some VB code:
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oView As DrawingView = Nothing
For Each oView In oDrawDoc.ActiveSheet.DrawingViews
If oView.Name = "VIEW1" Then
Exit For
Next
Dim viewCenter As Point2d = oView.Center
Dim viewpostition As Point2d = oView.Position
you can change the X and Y of these points
Herm Jan
Message 6 of 20
THX for your help.
But the code is old or vb.net? As I told, I am not a programmer. I can work with some code and edit it, change it. But I think that there isnt any code already for it... Smiley Sad
I found a "Automation" for a new drawing. But its old and much too complicted for me, because its too complex at all.
What I want to create is ...
- Add a new Sheet called "MachineSheet" *
- Resize Sheet to custom size for machinesize *
- Select the IAM from FirstSheet
- Add new View with IAM from FirstSheet in MachineSheet
- point new View to the left bottom corner exact to 0:0 with its left corner
- scale 1:1 *
- change view options *
* = already done
Message 7 of 20
Is it correct, that I have to calculate the left corner of the view out of its size?
The left bottom corner of the sheet,too.
And then point the calculated view point onto the sheetpoint???
Not realy?! Smiley Surprised
Message 8 of 20
Sub TryOne()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim dview As DrawingView
Set dview = oDoc.ActiveSheet.DrawingViews.Item(1)
Set oViewPos = ThisApplication.TransientGeometry.CreatePoint2d(dviewX, dviewY + 20)
dview.Position = oViewPos
End Sub
Thats what I have got so far.
What I now need is to change "+20" to "+ HalfSizeOfViewSizeY" and same for X-Achs.
Message 9 of 20
HermJan.Otterman
your getting there, I will help you.
this way you learn programming.
I use VB.net. with VBA you have to put some "set" and "call" statements.
a view has properties like: width and height, and there types are Double so:
- Dim halfWidth as Double = dView.Width/2
- Dim halfHeight as Double = dView.Height/2
you also have :
Dim viewScale as Double = dView.Scale
Herm Jan
Message 10 of 20
HermJan.Otterman
to get to the sheets:
Dim oSheets as sheets
set oSheets =Thisapplication.Activedocument.Sheets
this oSheets is a collection of all sheets. the first sheet is:
dim oFirstSheet as sheet
Set oFirstSheet = oSheets.item(1)
the .iam is linked to a view. so if you have one view then you know that it is item 1 of the views collection. if you have more views, then you will have to find the right view, by name.
dim oDrwView as DrawingView
Set oDrwView = oFirstSheet.drawingviews("NameOfTheView")
then you need the related IAM
dim oIAM as Inventor.Document
Set oIAM = oDrwView.ReferencedDocumentDescriptor.ReferencedDocument
Herm Jan
Message 11 of 20
Heart THX
Sub TryOne()
Set oDrawDoc = ThisApplication.ActiveDocument
Set oView = oDrawDoc.ActiveSheet.DrawingViews.Item(1)
Dim halfWidth As Double
halfWidth = oView.Width / 2
Dim halfHeight As Double
halfHeight = oView.Height / 2
Set oViewPos = ThisApplication.TransientGeometry.CreatePoint2d(oViewX + halfWidth, oViewY + halfHeight)
oView.Position = oViewPos
End Sub
Now last to do is to get the IAM from FirstSheet and insert it into the new sheet. Smiley Happy
I think best is do go to the active sheet as FirstSheet. Read the view(1) value and write it into array and than create the new sheet and insert the array as a new view.
Message 12 of 20
Thank you very much. So far what I got.
IAM source from first sheet selected ... I think.
New Sheet is createt.
Sheet resized.
Now I have to insert a new view with the source of IAM. Correct?
Some code is bad... but works so far. Smiley LOL
Sub Test()
'Document as drawing and set active
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = ThisApplication.ActiveDocument
'Sheets of active drawing
Dim oSheets As Sheets
Set oSheets = oDrawingDoc.Sheets
'Select first sheet of all
Dim oFirstSheet As Sheet
Set oFirstSheet = oSheets.Item(1)
'select first view in first sheet
Set oView = oFirstSheet.DrawingViews.Item(1)
'select IAM referenc from first view
Dim oIAM As Inventor.Document
Set oIAM = oView.ReferencedDocumentDescriptor.ReferencedDocument
'New Sheet
Dim oDrawingDocument1 As DrawingDocument
Dim oDrawingDocument2 As DrawingDocument
Dim oActSheets As Sheet
Set oActSheets = oDrawingDoc.ActiveSheet
Set oDrawingDocument1 = ThisApplication.ActiveDocument
Set oDrawingDocument2 = ThisApplication.Documents.Add(kDrawingDocumentObject, , False)
Set oSheet = oDrawingDocument2.Sheets.Item(oDrawingDocument2.Sheets.count)
oSheet.CopyTo oDrawingDocument1
oDrawingDocument2.Close True
For Each oActSheets In ThisApplication.ActiveDocument.Sheets
oActSheets.Activate
oSheetName = Left(oActSheets.Name, 5)
If oSheetName = "Blatt" Then
oDrawingDoc.ActiveSheet.Name = "Machine"
oActSheets.Size = DrawingSheetSizeEnum.kCustomDrawingSheetSize
oActSheets.Width = 250
oActSheets.Height = 160
MsgBox (oIAM)
Next
End Sub
Message 13 of 20
HermJan.Otterman
nice !!
go to the Inventor help, click Programming/Api help
Type "View"
go to the 4th line, Working with drawing views
(you see all VBA code!)
Dim oSheet As Sheet
Set oSheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint1 As Point2d
Set oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(5#, 5#)
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Open("c:\testpart.ipt", False)
Dim oView1 As DrawingView
Set oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc, _
    oPoint1, 1#, kBottomViewOrientation, kHiddenLineDrawingViewStyle)
Call oPartDoc.Close(True)
Herm Jan
Message 14 of 20
Thank you so much!
It works. Smiley Very Happy
Only one last thing. It adds the view as base (Mainview). But I have a special custom view for the iam.
How to change it? Cant finde any information for it and I dont knew how it is called in inventor. Smiley Surprised
Sub Test()
'New Sheet
oActSheets.Activate
MsgBox (oIAM)
Set oSheet = oDrawingDoc.ActiveSheet
Set oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(0#, 0#)
Set oView1 = oSheet.DrawingViews.AddBaseView(oIAM, oPoint1, 1#, kFrontViewOrientation, kHiddenLineDrawingViewStyle)
halfWidth = oView1.Width / 2
halfHeight = oView1.Height / 2
Set oView1Pos = ThisApplication.TransientGeometry.CreatePoint2d(oView1X + halfWidth, oView1Y + halfHeight)
oView1.Position = oView1Pos
Next
End Sub
Message 15 of 20
HermJan.Otterman
great that it works,
for the different views look in the API help for "DrawingViews object"
there you see the methods you can use like "addBaseView" or "AddProjectedView"
if you have you own special view, I thik you have to create a design view, in the assembly under representations.
then in code:
DrawingView.SetDesignViewRepresentation( Representation As String, [Associative] As Boolean )
Herm Jan
Message 16 of 20
Ok. I dont understand that code. Smiley Sad
In assembly is a representation view called "DXF". And the code have to change the Base (Main) to DXF.
Sub Ansicht()
Dim oViewRepr As DrawingView
Set oViewRepr = oActSheets.DrawingViews.Item(1)
Dim ReprView As String
ReprView = "DXF"
Set oView1 = oViewRepr.DrawingView.SetDesignViewRepresentation(ReprView, False)
End Sub
Message 17 of 20
HermJan.Otterman
can you try:
Set  oViewRepr.DrawingView.SetDesignViewRepresentation(ReprView, False)
or
call oViewRepr.DrawingView.SetDesignViewRepresentation(ReprView, False)
Herm Jan
Message 18 of 20
Call does work! Smiley Happy
But I dont knew the command "call".
What is it?
Thank you. Now the complete code does work. Smiley Very Happy Smiley Very Happy Smiley Very Happy
You are the man!!! I would spent a beer. Smiley Happy
Message 19 of 20
HermJan.Otterman
great that you got it to work!!
in VB.net and iLogic you don't need to use call.
I think you can see it as "execute" or "do" something.
Herm Jan
Message 20 of 20
Luisfmts
You're going straight to computer's heaven! Cause you just saved one of them from get smashed here.
Cheers
@HermJan.Otterman wrote:
can you try:
or
Smiley Very Happy
