CreateInstance(L"Inventor.Application") fails
rthelkap
rthelkap
A windows EXE application when creating an instance of Inventor fails with this error.
 Error = -2146959355,Description = (null),Message = Server execution failed
On our system this creates Inventor instance but it fails on a customer machine (windows 10, Inventor 2017) with the above error.
Sample code
ApplicationPtr m_spInvApp;
hr = m_spInvApp.CreateInstance(L"Inventor.Application");
if(FAILED(hr) || m_spInvApp == NULL)
_com_error err(hr);
_bstr_t bstrDesc = err.Description();
_bstr_t bstrMsg = err.ErrorMessage();
CString strErrMsg;
strErrMsg.Format(L"Error = %ld,Description = %s,Message = %s",err.Error(),(LPCTSTR)bstrDesc,(LPCTSTR)bstrMsg);
Any ideas on what could be the reasons for this error.
Thank You,
MechMachineMan
Don't use the "L".
hr = m_spInvApp.CreateInstance("Inventor.Application");
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
