iLogic to renumber partlist in assembly
I am searching for a code snipped to renumber the partlist in an assembly with start by 1 and ingrement by 1.
I only found some codes for the partlist in drawing documents.
Anyone who already uses something like that?
HermJan.Otterman
Look in Inventor, in the API help,
you can use this
BOMView.Renumber Method BOMView.Renumber( [StartValue] As Long, [Increment] As Long, [BOMRowsToRenumber] As Variant )
also from the help:
Using the BOM APIs API Sample
' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim FirstLevelOnly As Boolean
    If MsgBox("First level only?", vbYesNo) = vbYes Then
        FirstLevelOnly = True
    Else
        FirstLevelOnly = False
    ' Set a reference to the BOM
    Dim oBOM As BOM
    oBOM = oDoc.ComponentDefinition.BOM
    ' Set whether first level only or all levels.
    If FirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = True
    Else
        oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
     oBOMView = oBOM.BOMViews.Item("Structured")
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
This one works for me... (Frankensteined from @Anonymous and others)
You can sort by anything in the list: "0" is descending, "1" is ascending.
'sort parts list by PART NUMBER
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList As PartsList
oPartsList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
If Not oPartsList Is Nothing Then
'sort by part number Call oPartsList.Sort("PART NUMBER", 1, "ITEM QTY", 1)
'renumber the parts list oPartsList.Renumber
'save overrides to BOM oPartsList.SaveItemOverridesToBOM End If
First of all thanks for the help. 🙂
Herman, your code does resort the partlist in assemblies with a structure, but it doesnt renumber the items (parts). Maybe the info in the api can help. Hopefully it does. 😄
Curtis code renumber the parts, but only in drawings. I have no drawing for the assembly, because we export the partlist as excel sheets.
With Hermans code snipped I found the correct code in the forum to renumber the parts in assembly.
https://forums.autodesk.com/t5/inventor-customization/bomview-renumber/td-p/6885184
Thanks for the help! 🙂
