Create Folder for Symbols in drawings
Hi All,
In a drawing,
I need to create a list of folders from A to Z
and place all the Sketch Symbols in the right folder, by using the first letter of the symbol.
So all the symbols starting with letter A to folder A and so on.
Thanks for your help.
Best Regards
Massimo
MechMachineMan
There was a solution to something very similar posted yesterday...
https://forums.autodesk.com/t5/inventor-customization/copy-sketched-symbols-with-folders/td-p/713142...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
bshbsh
****, I didn't see it and wrote some code. You beat me to it. 🙂
I'll post mine anyway. It's vba.
Public Sub SS_Subfolders()
    If ThisApplication.ActiveDocument Is Nothing Then
        Exit Sub
    Else
        If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
            Dim InvDoc As Document
            Set InvDoc = ThisApplication.ActiveDocument
        Else
            Exit Sub
    Dim BP As BrowserPane
    Set BP = InvDoc.BrowserPanes.Item("Model")
    Dim SS_BN As BrowserNode
    Set SS_BN = BP.TopNode.BrowserNodes.Item("Drawing Resources").BrowserNodes.Item("Sketch Symbols")
    Dim SS_Coll As ObjectCollection
    Set SS_Coll = ThisApplication.TransientObjects.CreateObjectCollection
    Dim i As Long
    For i = 65 To 90
        SS_Coll.Clear
        For Each BrowserNode In SS_BN.BrowserNodes
            If (BrowserNode.NativeObject.Type <> kBrowserFolderObject) And (Left(BrowserNode.BrowserNodeDefinition.Label, 1) = Chr$(i)) Then
                SS_Coll.Add (BrowserNode)
        Next BrowserNode
        If SS_Coll.Count > 0 Then
            Set BF = BP.AddBrowserFolder(Chr$(i), SS_Coll)
    Next i
End Sub
Thanks, is it perfect!!
regards
Massimo
