set a part height to 0 when the part is suppressed
anyone know how to make the cone sit on top of a riser with no gap?
in the screenshot below, the cone is sitting at about 5 ft above the top riser, because the way it is constrained.
if I was able to set the suppressed riser heights to 0 (in this case riser 4 and 5 are suppressed), then this issue would be resolved.
any ideas?
Constrain parameter
Curtis_Waguespack
Hi Chhogori,
I think I would do this by suppressing constraints:
If RiserCount = 2 Then
	Component.IsActive("Lego Brick 2x2:2") = True
	Constraint.IsActive("Mate:2") = True
	Constraint.IsActive("Mate:3") = False
ElseIf RiserCount = 1 Then
	Component.IsActive("Lego Brick 2x2:2") = False
	Constraint.IsActive("Mate:2") = False
	Constraint.IsActive("Mate:3") = True
I hope this helps.
Curtis
Curtis,
thanks for the reply, I will try this out and see how it works.
thanks again for your help!
