Create a pattern based on excel input
hcdvree
hcdvree
I want to make a model in Inventor based on an Excel.
In Excel I've made a floor plan and I want to build an Part or Assembly with a Feature or Component Pattern based on that floor plan. So each cell with content gives a feature or component and each cell without content gives a suppress of a feature of component in the pattern.
Maybe there are more solutions to get a right model. Can you help me?
See floor plan in Attachement.
bradeneuropeArthur
Could you please try to explain a little more detailed about what you try to do.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
hcdvree
First we make a floor plan from a project in excel. Then we can easy calculate with this.
After that we want to read this excel in inventor (maybe ilogic) to become the correct sizes and to make a drawing with partslist to build this project. Each cel in excel with a 1, stands for 1 component in inventor. So it's a big pattern, but without fest startposition for each row and column.
What is the best solution to translate this file to a inventor model or assembly?
Best regards,
Henco de Vree
