Copy part number.iam to custom column in BOM with iLogic
BRLMCHKD
Message 1 of 26
BRLMCHKD
Hi there.
Could someone give me an idea, how to copy part number
to the custom column in BOM by use of iLogic - is it possible?
Thank you Smiley Happy
BRLMCHKD
Accepted solutions (3)
Replies (25)
Message 21 of 26
bradeneuropeArthur
take a look at the top right.
the checkbox "update partnumber…….." is checked...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 22 of 26
BRLMCHKD
Hi Brad.
Have tried different approaches, but copying not possible.
Message 23 of 26
bradeneuropeArthur
think this has nothing to do with the rule.
possiblities: ?
Is the file migrated to the latest version vault is needing.
Are the vault rules correctly used?
Is this file a special file like library of standard?
What lifecycle the file is in?
etc...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 24 of 26
BRLMCHKD
Hi Brad.
Yes that is correct.  I tried to delete the 1'st one, and took a new copy + implemented your rule,
and have taken two more copy designs of that without problems.
Your rule works, the column get auto filled with correct numbers 🙂
Really nice - Thank you a lot.
Message 25 of 26
Curtis_Waguespack
Hi @BRLMCHKD,
I didn't read all the other replies, but based on your information stating that Detail Dwg number needs to come from the part number of the occurrences I would use something like this:
' Get the active document. This assumes it Is a part document.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	oPartNumber = iProperties.Value(oOccurrence.Name, "Project", "Part Number")
	'find the postion Of the last ) In the name
	oPos = InStrRev(oPartNumber, ")",-1)
	'Get middle 10 chars of the part number starting at
	'position Of ), +1
	oPN = Mid(oPartNumber,oPos+1,10 )
    iProperties.Value(oOccurrence.Name, "Custom", "Detail Dwg") = oPN
Next
 I hope this helps.
Curtis
Message 26 of 26
bradeneuropeArthur
Hope the solution given will fulfill your needs.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
