Copy part number.iam to custom column in BOM with iLogic
BRLMCHKD
Message 1 of 26
BRLMCHKD
Hi there.
Could someone give me an idea, how to copy part number
to the custom column in BOM by use of iLogic - is it possible?
Thank you Smiley Happy
BRLMCHKD
Accepted solutions (3)
Replies (25)
Message 2 of 26
bradeneuropeArthur
Create a custom Property ie
"CompPartNumber" with the expression "=<Part Number>" (no "")
so no ilogic needed for this
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 26
clutsa
This should set the property to all first level parts...(needs tested against  sub-assemblies)
Dim app As Inventor.Application = ThisApplication
Dim doc As AssemblyDocument = app.ActiveDocument
Dim compDef As ComponentDefinition = doc.ComponentDefinition
Dim occ As ComponentOccurrence
For Each occ In compDef.Occurrences
	iProperties.Value(occ.Name, "Custom", "CustomColumnNameHere") = ThisDoc.FileName(False)
Next
I couldn't figure out how to make the custom column show in the BOM though... I imagine you can do an Import BOM Customization with something like
Dim BOM As BOM = compDef.BOM
BOM.ImportBOMCustomization("C:\Users\[userNameHere]\Desktop\CustomBOMExportNameHere.xml")
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 4 of 26
Curtis_Waguespack
Hi @BRLMCHKD
You can use something like the first example to get the 9 right most characters of the assembly file name and  then write that value to a custom iproperty in each occurrence file.
If the part number is not always 9 characters then we could use the ")" character to find the start point of the part number, as in the 2nd example.
I hope this helps.
Curtis
Dim HasDrawing_List As New ArrayList
' Get the active document. This assumes it is a part document.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oPN = Right(ThisDoc.FileName(False),9)
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	oDDoc = oOccurrence.Definition.Document
	iProperties.Value(oOccurrence.Name, "Custom", "Detail Dwg") = oPN
Next
' Get the active document. This assumes it Is a part document.
Dim oName As String
oName = ThisDoc.FileName(False) 'without extension
'Get length Of file name
oLen = Len(oName)
'find the postion Of the last ) In the name
oPos = InStrRev(oName, ")",-1)
'Get middle part Of String starting at
'position Of ), +1
oPN = Mid(oName,oPos+1,(oLen - oPos) )
Next
Message 5 of 26
BRLMCHKD
Hi bradeneurope.
Message 6 of 26
bradeneuropeArthur
You asked for the Part Number!
The Part Number is the Same as shown in your pictures.
Do you have an overview what you understand with Part Number?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 26
BRLMCHKD
Hi.
I have to update my wish, to avoid misunderstandings.
See my updated snag shot of what I'm trying to automate.
Many thanks for all your kind answers Smiley Happy
Message 8 of 26
BRLMCHKD
Hi.
I have tried your iLogic, and found it working, on the basis of the first assumptions I gave in my question.
But I have just learned that the Detail Dwg column, must follow the part numbers that vary with different numbers,
in the assembly.
Therefore my question remains open, see my last uploaded revised question Smiley Happy
Message 9 of 26
bradeneuropeArthur
Differs your partnumber (Inventor Part Number) in length and format?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 26
BRLMCHKD
Hi.
Yes my partnumber do differs, but the prefix always starts with the same number of digits like e.g.s below.
10270 HAH20 052 Noz6_45degLeft.ipt
10390 HAH10 025 CbFl1.ipt
10400 HAH30 010 InletNoz.ipt
The digits i wants to copy, is number 7 to 15 (the underlined)  Smiley Happy
KR
Message 11 of 26
bradeneuropeArthur
ok that is clear.
do you like to add a ilogic code to your part(s) or do you like to have an ilogic code in your assembly (only)?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 26
BRLMCHKD
Hi.
I think the simplest solution for me, would be to have an iLogic code in the assembly Smiley Happy
Message 13 of 26
bradeneuropeArthur
let's give it a try......
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 26
bradeneuropeArthur
Public Sub PartNumber()
Dim a As AssemblyDocument
Set a = ThisApplication.ActiveDocument
Dim b As AssemblyComponentDefinition
Set b = a.ComponentDefinition
Dim c As ComponentOccurrence
For Each c In b.Occurrences
MsgBox c.Name
Dim x As Document
Set x = c.Definition.Document
MsgBox x.DisplayName
Dim Partnumber As String
Partnumber = VBA.Left(x.DisplayName, 15)
Partnumber = VBA.Right(Partnumber, 8)
Dim p As Property
On Error Resume Next
x.PropertySets.Item(4).Add Partnumber, "detail dwg"
If Error Then
Set p = x.PropertySets.Item(4).Item("detail dwg")
p.Value = Partnumber
Err.Clear
MsgBox x.PropertySets.Item(1).Item(1).Name
Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 26
bradeneuropeArthur
for I logic:
 Sub Main()
MsgBox (c.Name)
Dim x As Document
MsgBox (x.DisplayName)
Partnumber = Left(x.DisplayName, 15)
Partnumber = Right(Partnumber, 8)
Dim p As Inventor.Property
Try
x.PropertySets.Item(4).Add (Partnumber, "detail dwg")
Catch ex As Exception
	End Try
MsgBox (x.PropertySets.Item(1).Item(1).Name)
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 26
BRLMCHKD
Hi.
Maybe it's not so simpel / easily to do that task with iLogic (?)
It's no big matter, it had just been a help /smart work around to avoid manually entering these numbers Smiley Happy
Message 17 of 26
bradeneuropeArthur
please remove the msgboxes.
are you a little familiar with programming?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 26
BRLMCHKD
Hi.
No I am not very familiar with programming, but try with great energy to learn something basic knowledge of iLogic 🙂
But I guess I can just remove the msg boxes with putting the (') in front of them
'MsgBox (#.###)
Message 19 of 26
bradeneuropeArthur
that is correct...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 26
BRLMCHKD
Hi Brad.
Your rule seems to work correctly, at least partly.
Correcting in BOM of the detail drwg. numbers works correct.
But now it seems, that I cannot be able to make 'Copy Design' in Vault, of the particular iam, where I was testing your rule(?)  Do you got a clue of what can be wrong?
