COPY parameters via iLogic between 2 ipt parts
mblaptok
Message 1 of 8
mblaptok
I've got 2 files A.IPT and B.IPT, which are not linked (i don't want it). All i want i just copy parameters via iLogic (not interested by import/export to xml)
I tried this code (run from file A.IPT), but i have an error "...B.IPT was not found"
Parameter("partA") = Parameter("B.IPT", "partB")
 What should I do, that Inventor will see B.IPT and than copy parameters.
Is there a simple solution for it? (without linking!)
Thank's
Replies (7)
Message 2 of 8
bradeneuropeArthur
Maybe this is an option:
derive A in B and than Break Link with A....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
mblaptok
Thank's but  this is not an option, these are independent parts, moreover, once I want to copy parameters from A to B, and another time from B to A.
I also don't want to create an additional file eg. C.IPT with parameters (linked to A&B)
Message 4 of 8
bradeneuropeArthur
Could this help you?
Public Sub main()
Dim a As Application
a = ThisApplication
Dim thispart As PartDocument
 thispart = a.ActiveDocument
Dim b As FileDialog
Call a.CreateFileDialog(b)
b.FileName = "" '"C:\Temp\Temp.ipt"
b.Filter = "Inventor Part Files (*.ipt)|*.ipt"
b.ShowOpen
Dim refdoc As PartDocument
refdoc = a.Documents.Open(b.FileName, False)
Dim pa As Parameter
pa = refdoc.ComponentDefinition.Parameters.Item("YourName")
thispart.ComponentDefinition.Parameters.UserParameters.AddByValue (pa.Name, pa.Value,"mm")
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
bradeneuropeArthur
Modified a little to have the correct units
Public Sub main()
a = ThisApplication
Dim b As FileDialog
b.FileName = "d:\"
b.ShowOpen
MsgBox b.FileName
Dim pa As Parameter
Set pa = refdoc.ComponentDefinition.Parameters.Item("YourName")
thispart.ComponentDefinition.Parameters.UserParameters.AddByValue pa.Name, pa.Value, pa.Units
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 8
mblaptok
Thank You.
I removed file filtering (not needed), generally it works, but there is one big problem, if a parameter with the same name exists, it is not updated, but a new one is created with the index _1 : /
how to overcome this ?
or maybe some other method, shorter ...?
Public Sub Main()
a = ThisApplication
refdoc = a.Documents.Open("D:\FILE.IPT", False)
Dim pa As Parameter
pa = refdoc.ComponentDefinition.Parameters.Item("test1")
thispart.ComponentDefinition.Parameters.UserParameters.AddByValue(pa.Name, pa.Value, pa.Units)
End Sub
Message 7 of 8
bradeneuropeArthur
Public Sub Main()
a = ThisApplication
Dim pa As Parameter
Try
	thispart.ComponentDefinition.Parameters.UserParameters.Item(pa.name).Value = pa.Value
Catch
End Try
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
mblaptok
Works good, thank's a lot !
I modified UserParameters, i left just Parameters... (i have both)
Try
Catch
End Try
In parallel, I solved it in a similar way,  it also works good.
Dim oModel As PartDocument
Dim doc = ThisDoc.WorkspacePath
FilePath = doc + "\TEST.IPT"
oModel = ThisApplication.Documents.Open(FilePath, False)
auto = iLogicVb.Automation
Parameter("test1") =   auto.ParamValue(oModel, "test1")
