Copy iProperties
Copy iProperties
GeorgK
Advisor Advisor
Message 1 of 9
Copy iProperties
GeorgK
Hello together,
how could I copy all iProperties from one part to another part in an assembly?
Thank you Georg
Replies (8)
Message 2 of 9
MechMachineMan
Copy Design Properties might be a tool to look into.
Otherwise, how many files do you need to do this for? More detail is always cool too.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 9
GeorgK
Hello Justin,
the tool is very good for some cases. But I need it a bit more flexible. Do you have an idee how to copy the iproperties to clipboard?
Georg
Message 4 of 9
GosponZ
Hi George,
try this one i'm using for long time. Working good for me. You just add as many iproperties you need. There is one for e.g.
Hope it will help you. Run rule from assembly
Dim oDoc As Document = ThisDoc.Document
Dim oRefDoc As Document
For Each oRefDoc In oDoc.AllReferencedDocuments
	If oRefDoc.DocumentType = kPartDocumentObject Then
		modelName = IO.Path.GetFileName(oRefDoc.FullFileName)
	Try
		' Set the value
		iProperties.Value("Project", "Description") = iProperties.Value(modelName, "Project", "Description")
	Catch
	End Try
Next
iLogicVb.UpdateWhenDone = True
Message 5 of 9
Simple code to copy description to clipboard:
Imports System.Windows.Forms
Sub Main
  Dim Description As String = iProperties.Value("Project", "Description")
  Clipboard.SetText(Description)
End Sub
Message 6 of 9
GeorgK
Hello MisterZ,
thank you very much for your help. I try it tomorrow.
Georg
Message 7 of 9
MechMachineMan
Another thing you could do for customization is write them all to an excel
file, change it in there and have them write back.
Justin K
Message 8 of 9
GeorgK
Is it possible to copy and paste the material as well?
Georg
Message 9 of 9
MechMachineMan
Yes, it is. Unless it is in your library in that part, then it might be a little more difficult. If you just need the name, it's still very simple.
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Justin K
