WTH happeneed to my form?
I had an add-in created which launched a form. On the form were/are 4 radio buttons to choose units/precision. Just a 1-4 choice.
It WAS working. In tweaking underneath code that had nothing to do with the dialog - the dialog stopped functioning correctly - this is the code i've added:
Imports Inventor Public Class CUForm2 Dim oUnits As String Dim otext As String Public Sub New() ' This call is required by the designer. InitializeComponent() ' Add any initialization after the InitializeComponent() call. If RBin.Checked = True Then oUnits = "ft-in" End If If RBmm.Checked = True Then oUnits = "mm" End If If RBmm1.Checked = True Then oUnits = "mm1" End If If RBmm2.Checked = True Then oUnits = "mm2" End If MsgBox("unit type " & oUnits) End Sub
i tried a new form from scratch and i'm getting the same problem.
Basically, the if/thens are firing before the dialog appears. The dialog, does appear, but regardless of what you choose, none of the if statements are catching.. (i know i'm supposed to do me.close at the end, but nothing is working.
I've also tried the new statement as
Private Sub CUnits_Click(sender As Object, e As EventArgs) Handles CUnits.Click
I've tried that with elseif's and select case and same thing happenes. I don't see what i'm missing here.
Help would be appreciated as i'm clearly missing something here.
Thanks!
