Copy Faces In One Part, Sculpt to another
cencinaNB2ET
cencinaNB2ET
The trimming process seems to be very widely used.
As Seen on this thread:
https://forums.autodesk.com/t5/inventor-forum/trimming-intersecting-parts-in-an-assembly/td-p/281259...
but I have an issue that i wont know that parts will be in my assembly and need to automate this process.
So far I only found a similar code from Brain Ekins:
http://adndevblog.typepad.com/manufacturing/2013/09/copying-a-body-from-one-part-into-another-part.h...
But it only addresses kPartBodyFilter as SurfaceBodyProxy
I tried looking into the API to know how to change that selection to a face but was not able to.
Im after not having a selection process but rather a predetermined face number example: face(3)
Then comes the sculpting process, which I believe its much more straight forward.
Any ideas???
JaneFan
To change selection filter to face:
Dim oFace As FaceProxy
Set oFace = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select a Face to copy.")
Jane Fan
Inventor/Fusion QA Engineer
