Copy design: Template for copy
Is it possible either via an existing plugin or via vault to save copy design's copy/reuse settings?
Basically, we have certain IAM's we copy over multiple times with the copy design. about 60% of the contained IPT's need to be reused, the remaining 40% need to be copied. currently we select them manually each time, and it could happen that some of them are forgotten. What i would like is to have a List, in wich names of files are defined. If I load the copy design window, and it contains any of those files, then those files are automatically set to reuse by default.
Is there a tool that does something like this?
Thanks!
bradeneuropeArthur
Maybe @Anonymous or @jpossen can help you with this question?
Think that this is not possible at the moment.
Maybe in future, rules can do something with this!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
w.pepping
I think it should be possible with our Copy Design Tool. It need some changes to handle it.
Do you have a static list with the reused files?
Get control of your sheet metal files.
Download the app from matprop.com
Hello, thanks for the answer... Ideally it would be a strict list of filenames in a txt file, that ia placed centrally on the lan so every pc can access it.. The alternatove would be a list of folders in vault, and all files that are inside those folders are set to reuse... Will have a look at your link in the office tomorrow..
Thank you very much
Just to clarify, I am talking about the Copy design that is inside VAULT, not inside inventor...
nobody?
paul.hurley
I have created a application that can copy templates, but it does require the assembly templates to conform to certain rules. once the templates are set up we can copy them with all the standard components and library items being re-used and all the custom parts which may need to be manipulated get assigned new part numbers. Also the drawings get copied with the template too. the tool also has a number generator which also works to specific rules.
If you need some help please get back to me, i could show you some samples of how this works.
Cheers Paul
