Control Definition Not Receiveing Selection Set
MechMachineMan
Advisor Advisor
MechMachineMan
I've got the code below;
The control works fine when I select the object manually and run it, but when I try to get the program to select it, it does not run.
I've tried analyzing objects in the vba environment, and it looks like everything is as expected.... The control definition is just not receiving/processing the select set object.
What is going wrong/how do I fix this/how do I figure out how to fix this?
- Justin
Attached:
'Vb.net 'Dim oDoc As Document'oDoc = ThisApplication.ActiveDocument'
'Dim oSS As SelectSet'oSS = oDoc.SelectSet'
'oSS.Select(oDoc.ActiveSheet.DrawingNotes.GeneralNotes.Item(1))'
'oDoc.Update'
'Dim oCommandMgr As CommandManager'oCommandMgr = ThisApplication.CommandManager'
'Dim oControlDef1 As ControlDefinition'oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingGeneralNoteEditCtxCmd")'oControlDef1.Execute2(True)
'vba
Set oDoc = ThisApplication.ActiveDocument
Set oSS = oDoc.SelectSet
oDoc.Update
Set oCommandMgr = ThisApplication.CommandManager
Set oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingGeneralNoteEditCtxCmd")
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Curtis_Waguespack
@MechMachineMan, I was just trying to do something similar.
Do you ( or anyone else who happens to read this) know how to get this to work?
Or know of another way to open the text editor dialog of a code selected general note?
I noticed it works as expected if the item is preselected, or if the interactively selected item is a leader note.
But not if we try to select a general note via code.
@MjDeck , @chandra.shekar.g can you tell us if there is bug here?
see attached Inventor 2022 example file.
Preselect the leader note, run the internal rule: works as expected
Preselect the general note, run the internal rule: works as expected
Clear the selection set, run the internal rule and select a leader note interactively: works as expected
Clear the selection set, run the internal rule and select a general note interactively: does not work
Dim oSSet As SelectSet = ThisApplication.ActiveDocument.SelectSet
If oSSet.Count = 0 Then
	Try
		oNoteBox = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingNoteFilter, "Select text object.")
		oSSet.Select(oNoteBox)
	Catch ex As Exception
		MsgBox(ex.Message)
	End Try
Else
	oNoteBox = oSSet.Item(1)
If Not oNoteBox Is Nothing Then
	If oSSet.Item(1).Type = ObjectTypeEnum.kGeneralNoteObject Then
		ThisApplication.CommandManager.ControlDefinitions.Item("DrawingGeneralNoteEditCtxCmd").Execute
	ElseIf oSSet.Item(1).Type = ObjectTypeEnum.kLeaderNoteObject Then
		ThisApplication.CommandManager.ControlDefinitions.Item("DrawingLeaderEditTextCtxCmd").Execute
Else
	MsgBox("oNoteBox = nothing")
MjDeck
@Curtis_Waguespack , yes there is a bug. Thanks for investigating this. It is internal number INVGEN-65247. It looks like it's easy to fix.
I don't see a workaround other than pre-selecting the general note before you run the rule.
Mike Deck
Software Developer
Autodesk, Inc.
Curtis_Waguespack
 @MjDeck, Thank you for taking a look at this and confirming the issue.
Unfortunately, I have a customer that has a requirement for this for a drawing automation tool using Inventor 2023.
I'll try and figure out a different workflow, but if a fix for this were to end up in a future update to Inventor 2023 that would be outstanding 😉 ( I know you can't comment on future updates, etc)
Thanks again.
