Control Definition Not Receiveing Selection Set
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've got the code below;
The control works fine when I select the object manually and run it, but when I try to get the program to select it, it does not run.
I've tried analyzing objects in the vba environment, and it looks like everything is as expected.... The control definition is just not receiving/processing the select set object.
What is going wrong/how do I fix this/how do I figure out how to fix this?
- Justin
Attached:
'Vb.net 'Dim oDoc As Document'oDoc = ThisApplication.ActiveDocument' 'Dim oSS As SelectSet'oSS = oDoc.SelectSet' 'oSS.Select(oDoc.ActiveSheet.DrawingNotes.GeneralNotes.Item(1))' 'oDoc.Update' 'Dim oCommandMgr As CommandManager'oCommandMgr = ThisApplication.CommandManager' 'Dim oControlDef1 As ControlDefinition'oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingGeneralNoteEditCtxCmd")'oControlDef1.Execute2(True) 'vba Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument Dim oSS As SelectSet Set oSS = oDoc.SelectSet oSS.Select(oDoc.ActiveSheet.DrawingNotes.GeneralNotes.Item(1)) oDoc.Update Dim oCommandMgr As CommandManager Set oCommandMgr = ThisApplication.CommandManager Dim oControlDef1 As ControlDefinition Set oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingGeneralNoteEditCtxCmd") oControlDef1.Execute2(True)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
