Content Center Editing
I currently work with Inventor 2014 and have been tasked with updating and fixing our content center. The content center is stored on a server and I have been given administrative access to in order to edit it. The content center library that we use consists of all custom parts in a read/write environment. However, it seems as though I don't have access to many of the editing features that I need. I am unable to update and map parameters, create or delete categories, or delete or update families. I can add more options and sizes into our current library but this is little help when the parts themselves need to be edited and have additional parameters added.
Is this an issue that others have run into? Do I need to work on the same computer that the server is hosted on in order to have full access to make edits as required? Again, I have the highest possible access level and seem to have limited editing options.
Bryan Dyck
MechMachineMan
Check out this blog.
https://synergiscadblog.com/2014/02/28/working-with-inventor-content-center-part-1-of-3/
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
