Consolidate flat pattern of multiple parts from an assembly
Message 1 of 22
I have an assembly with 500 parts and around 200 parts are sheet metal.
1) The procedure i follow is create a drawing file for each part and place the flat pattern developed view in the drawing for each part.(Repeated 200 times)
2) Then I create a development.drw and copy paste this view from all the drawings one by one.( Repeat task 200 times open and copy)
3) Next I copy this drawing into autocad and do the nesting for laser cutting.
I want to get all the falt patterns from these parts in one place with their part numbers without doing the repetitive task.
Can anyone provide the best and the fastest solution for this? I am using Inventor 2011. I know it can be done using vba but i am unable to write a code. Please Help !
Sid
Replies (21)
Message 2 of 22
Hello.
I have a similar problem!
What I try to do is place all the developed flat patterns onto onto a very large sheet at a 1:1 scale.
I can open  parts using this code (posted below) which I found on here.
I now have to manually place all the sheetmetal flat patterns onto the sheet - any code which could do this would be a real help.
Code to place the flat pattern of all open parts onto the same drawing.
The drawing can then be exported for nesting & laser cutting.
Assigns a sheet metal rule to the part & creates a flat patten
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'Change Document.SubType to Sheetmetal
oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
iProperties.Material = "Stainless Steel 304"
SheetMetal.SetActiveStyle("StSt-6mm 50mmV")
iProperties.PartColor = "Yellow"
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
''ThisDoc.Launch(ThisDoc.PathAndFileName(True))
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
    oCompDef.Unfold
Else
   oCompDef.FlatPattern.Edit
ThisDoc.Save
open assembly parts:
'Define the open document
Dim oDoc As Document
oDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In oDoc.AllReferencedDocuments
'open the indexed file'true opens the file normaly'false opens the file programatically without generating the graphics
ThisApplication.Documents.Open(docFile.FullFileName, True)
Next
I hope someone can expand on this.
Andrew
Message 3 of 22
MechMachineMan
Here is an extensive program I used that did as you need (and seperated by thickness too!)
May need some extensive rework to exactly suit your needs and could likely also use some refactoring as this was earlier in my programming days.
Sub Main()
Dim oTextSave As String = "C:\Windows\Temp\iLogicBuffer.txt"
oWrite = System.IO.File.CreateText(oTextSave)
oWrite.Close
Dim oDoc As AssemblyDocument
Dim oCompDef As AssemblyComponentDefinition
Dim oBOM As BOM
oBOM = oCompDef.BOM()
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
	If oBOMRow.BOMStructure = BOMStructureEnum.kInseparableBOMStructure Or oBOMRow.BOMStructure = BOMStructureEnum.kVariesBOMStructure 'Or oBOMRow.Merged = True
		MsgBox("Changes to BOM struture required")
		Exit Sub
		'oBOMRow.BOMStructure = kNormalBOMStructure
Next
'Create Dwg Document
Dim oDwgDoc As DrawingDocument
'oDwgDoc = ThisApplication.Documents.Add(kDrawingDocumentObject,"X:\CAD Library\Templates\Inventor 2016\Dyna Approved\Dyna.idw", True)
oDwgDoc = ThisApplication.Documents.Add(kDrawingDocumentObject,"C:\Users\Rob\Desktop\PROFILE CREATION TEMPLATE.idw", True)
Dim oSheets As Sheets = oDwgDoc.Sheets
Dim oSheet As Sheet
oSheet = oDwgDoc.Sheets.Item(1)
Try
	oSheet.TitleBlock.Delete
	oSheet.RevisionTables.Item(1).Delete
Catch
End Try
'oSheet.Size = DrawingSheetSizeEnum.kCustomDrawingSheetSize
'oSheet.Height = 144 * 2.54
'oSheet.Width = 72 * 2.54
'Try
'	ThisApplication.SilentOperation = True
'	ThisApplication.ScreenUpdating = False
	oPlaceViews(oBOMView, oDwgDoc)
'	ThisApplication.ScreenUpdating = True
'	ThisApplication.SilentOperation = False
'Catch
'End Try
'Clean-up of sheets
For Each oSheet In oSheets
	If oSheet.DrawingViews.Count = 0
		oSheet.Delete
Next
Dim oNView As DrawingView
	oSheet.Activate
	Dim oMaxHeight As Double = 0
	Dim oMaxWidth As Double = 0
	Dim oSaveHeight As Double = 0
	Dim oNewLoc As Point2d
	For Each oNView In oSheet.DrawingViews
			If oNView.Height > oMaxHeight
				oMaxHeight = oNView.Height
		If Not oNView.Name Like "PLATE*"
			If oNView.Width > oMaxWidth
				oMaxWidth = oNView.Width
		Else
			If oNView.Width > oPlateMaxWidth
				oPlateMaxWidth = oNView.Width
	Next
	oWidth = 0.8*oPlateMaxWidth
	oHeight = 0.7*oMaxHeight
		If oNView.Name Like "PLATE*"
			oNewLoc = ThisApplication.TransientGeometry.CreatePoint2d(oWidth, oHeight)
			oNView.Position = oNewLoc
			oHeight = oHeight + oMaxHeight
			oAddSketchedSymbol(oNView, oMaxWidth)
	Next
	oWidth = oWidth + .8*(oMaxWidth + oPlateMaxWidth)
	oHeight = .7*oMaxHeight
		If oNView.Name Like "FLAT*"
	Next
	oWidth = oMaxWidth + oWidth
		If oNView.Name Like "BENT*"
	Next
Next
'ThisApplication.ScreenUpdating = True
Process.Start ("Notepad.exe",oTextSave)
End Sub
Sub oPlaceViews(oBOMView As BOMView, oDwgDoc As DrawingDocument)
oWrite = System.IO.File.AppendText(oTextSave)
Dim oTtlQty As Integer
Dim oUOM As UnitsOfMeasure
oUOM = ThisApplication.ActiveDocument.UnitsOfMeasure
Dim oCurrentHeight As Double
oCurrentHeight = 0
Dim oCurrentHeight2 As Double ' For Bent ****
oCurrentHeight2 = 0
Dim oFP As Boolean = False
'ThisApplication.ScreenUpdating = False
Dim i As Integer = 0
	oFP = False
	oTtlQty = oBOMRow.TotalQuantity
	oIQty = oBOMRow.ItemQuantity
'Get appropriate component definition
	Dim oBOMItem As ComponentDefinition
	oBOMItem = oBOMRow.ComponentDefinitions.Item(1)
	If oBOMItem.Type = ObjectTypeEnum.kVirtualComponentDefinitionObject Or _
		Not oBOMItem.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value Like "PL*"
		Continue For
	Dim oBDoc As Document
	oBDoc = oBOMItem.Document
	Try
	oBDoc.PropertySets.Item("Inventor User Defined Properties").Item("TtlQty").Value = oTtlQty
	Catch
	oBDoc.PropertySets.Item("Inventor User Defined Properties").Add(oTtlQty, "TtlQty")
	End Try
	If oBOMItem.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject
			If oBOMItem.HasFlatPattern = True
				oBOMItem = oBOMItem.FlatPattern
			Else
			Try
			oBOMItem.Document.Unfold
			Catch
				'MsgBox("Error In Generating Flat Pattern for " & oBOMItem.Document.FullFileName)
				oWrite.WriteLine("Error In Generating Flat Pattern for " & oBOMItem.Document.FullFileName)
			End Try
		oFP = True
'Get Bounding Box/Orientation of FACE
	Dim oVO As ViewOrientationTypeEnum
	Dim oRt As Double
	oBOX = oBOMItem.RangeBox
	oXDif = oUOM.ConvertUnits(Abs(oBOX.MaxPoint.X - oBOX.MinPoint.X), "cm", "in")
	oYDif = oUOM.ConvertUnits(Abs(oBOX.MaxPoint.Y - oBOX.MinPoint.Y), "cm", "in")
	oZDif = oUOM.ConvertUnits(Abs(oBOX.MaxPoint.Z - oBOX.MinPoint.Z), "cm", "in")
	'MsgBox("TtlQty: " & oTtlQty & " IQty: " & oIQty & vbLf & _
	'	   "XDif: " & oXDif & vbLf & _
	'       "YDif: " & oYDif & vbLf & _
	'	   "ZDif: " & oZDif)
	If (oXDif > oYDif And oYDif > oZDif)
		oLength = oXDif
		oWidth = oYDif
		oThickness = oZDif
		oFace = "XY"
		oVO = ViewOrientationTypeEnum.kFrontViewOrientation
		oRt = 0
	Else If oYDif > oZDif And oZDif > oXDif
		oLength = oYDif
		oWidth = oZDif
		oThickness = oXDif
		oFace = "YZ"
		oVO = ViewOrientationTypeEnum.kRightViewOrientation
		oRt = 90*(Math.PI/180)
	Else If oZDif > oXDif And oXDif > oYDif
		oLength = oZDif
		oWidth = oXDif
		oThickness = oDdif
		oFace = "ZX"
		oVO = ViewOrientationTypeEnum.kTopViewOrientation
	Else If oZDif > oYDif And oYDif > oXDif
		oLength = oZDif
		oWidth = oYDif
		oThickness = oXDif
		oFace = "ZY"
		oRt = 0
	Else If oYDif > oXDif And oXDif > oZDif
		oLength = oYDif
		oWidth = oXDif
		oThickness = oZDif
		oFace = "YX"
	Else If oXDif > oZDif And oZDif > oYDif
		oLength = oXDif
		oWidth = oZDif
		oThickness = oYDif
		oFace = "XZ"
		oRt = 0
	Else If oXDif = oYDif
		oLength = oXDif
		oWidth = oYDif
		oThickness = oZDif
		oFace = "XY"
		oRt = 0
	Else If oZDif = oYDif
		oLength = oZDif
		oWidth = oYDif
		oThickness = oXDif
		oFace = "ZY"
		oRt = 0
	Else If oXDif = oZDif
		oLength = oXDif
		oWidth = oZDif
		oThickness = oYDif
		oFace = "XZ"
		oRt = 0
	Else
		MsgBox("I am confused")
'MsgBox(oFace)
'Select Sheet
	Select Case Math.Round(oThickness, 4)
		Case 6
			oSheets.Item(1).Activate
		Case 5
			oSheets.Item(2).Activate
		Case 4.5
			oSheets.Item(3).Activate
		Case 4
			oSheets.Item(4).Activate
		Case 3.5
			oSheets.Item(5).Activate
		Case 3
			oSheets.Item(6).Activate
		Case 2.5
			oSheets.Item(7).Activate
		Case 2
			oSheets.Item(8).Activate
		Case 1.75
			oSheets.Item(9).Activate
		Case 1.5
			oSheets.Item(10).Activate
		Case 1.25
			oSheets.Item(11).Activate
		Case 1
			oSheets.Item(12).Activate
		Case .75
			oSheets.Item(13).Activate
		Case .625
			oSheets.Item(14).Activate
		Case .5
			oSheets.Item(15).Activate
		Case .375
			oSheets.Item(16).Activate
		Case .3125
			oSheets.Item(17).Activate
		Case .25
			oSheets.Item(18).Activate
		Case .1875
			oSheets.Item(19).Activate
		Case .1345, .1382, .1019, .1406 '10 gauge
			oSheets.Item(20).Activate
		Case .1046, .1084, .0808, .1094 ' 12 Ga
			oSheets.Item(21).Activate
		Case .0747, .0785, .0641, .0781 '14 Ga
			oSheets.Item(22).Activate
		Case .0598, .0635, .0508, .0625 '16 Ga
			oSheets.Item(23).Activate
		Case .0478, .0516, .0403, .0500 '18 Ga
			oSheets.Item(24).Activate
		Case Else
			oSheets.Item(25).Activate
		End Select
	Dim oViews As DrawingViews
	oViews = oDwgDoc.ActiveSheet.DrawingViews
	Dim oView As DrawingView
	Dim oViewLoc As Point2d
	Dim oBaseViewOptions As NameValueMap
	oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oBaseViewOptions.Add("SheetMetalFoldedModel", False)
	If oFP = False
		oViewLoc = ThisApplication.TransientGeometry.CreatePoint2d(10*2.54, oCurrentHeight + .6*oWidth*2.54)
		oCurrentHeight = oCurrentHeight + oWidth*2.54
		oView = oViews.AddBaseView(oBOMItem.Document, oViewLoc, 1, oVO, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
		oView.Rotation = oRt
		oView.Name = "PLATE" & i
		i=i+1
	Else
		oViewLoc = ThisApplication.TransientGeometry.CreatePoint2d(100*2.54, oCurrentHeight2 + .6*oWidth*2.54)
		oView = oViews.AddBaseView(oBOMItem.Document, oViewLoc, 1, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle,,,oBaseViewOptions)
		oView.Name = "FLAT" & i
		i=i+1
		oViewLoc = ThisApplication.TransientGeometry.CreatePoint2d(300*2.54, oCurrentHeight2 + .6*oWidth*2.54)
		oView.Name = "BENT" & i
		i=i+1
		oCurrentHeight2 = oCurrentHeight2 + oWidth*2.54
Next 'BOMRow
oWrite.Flush
oWrite.Close
End Sub
Sub oAddSketchedSymbol(oView As DrawingView, oMaxWidth As Double)
		Dim oCurve As DrawingCurve = oView.DrawingCurves.Item(1)
		Dim oPoint As Point2d = oCurve.MidPoint
		If oPoint Is Nothing
			oPoint = oCurve.CenterPoint
		Dim oSSD As SketchedSymbolDefinition = ThisApplication.ActiveDocument.SketchedSymbolDefinitions.Item("Part Label")
		Dim oLeaderPoints As ObjectCollection
		oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
		Dim oPlacementPoint As Point2d
		oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oView.Position.X - (1.5*oMaxWidth), oView.Position.Y)
		oLeaderPoints.Add(oPlacementPoint)
		Dim oGeometryIntent As GeometryIntent
		oGeometryIntent = ThisApplication.ActiveDocument.ActiveSheet.CreateGeometryIntent(oCurve)
		oLeaderPoints.Add(oGeometryIntent)
		Dim oS1 As SketchedSymbol
	Try
		oS1 = ThisApplication.ActiveDocument.ActiveSheet.SketchedSymbols.AddWithLeader(oSSD,oLeaderPoints, 0, oMaxWidth/20, ,False,True)
		oS1.LeaderVisible = False
	Catch
	End Try
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 22
matt_jlt
Hi,is there a requirement that each flat pattern needs to be on a drawing with titleblock?
Have you considered the option of exporting the flat patterns directly from the parts / assembly.
You can iterate through all of the parts and export them to DXF / DWG?
Regards, Matt.
Message 5 of 22
tolgay.hickiran
Hey we've been trying to use your code but unable to find a way to. It looks like VB Editor code inside inventor but it has lots of red lines once we copy paste it. Which environment were you using this on. We also tried using it on Visual Studio and failed to use it there too.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
Message 6 of 22
MechMachineMan
Use it straight in a rule rather than through either of those environments.
Justin K
Message 7 of 22
tolgay.hickiran
Hello mmm, we've tried many different ways to use your code but its a no go. We probably failed hard here.
Tolgay Hickiran
Founding Partner
SignatureSignature
website
Message 8 of 22
Jef_E
I had a quick glance at the code, and I wonder did you edit this line??
If not it will end bad 😄 for the rest it seems to be working for me? Don't know what it does, but it does not give any errors when running the rule.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 9 of 22
Thanks for posting this - been busy! ( lots of time spent placing individual flat parts onto a dwg!)
I've put the code into a new rule & edited the template path - the rule runs, opens a text window, opens a drawing but it's blank - need to investigate - further - like the idea, hope I can use it!
Message 10 of 22
I assume you have flat patterns already created to ipts. Here is one code sample(VBA) that should do the trick. You can modify the code to your case. Copy the attached(zipped) ini-file to C:\
Public Sub CreateDXFDrawing()
'Create sheet for sheetmetal parts with flatpattern
'Get Inventor and Document
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Set oDoc = oApp.ActiveDocument
Dim oDrawing As DrawingDocument
Set oDrawing = oApp.Documents.Add(kDrawingDocumentObject)
'oApp.SilentOperation = True
Dim oDXFSheet As Sheet
Set oDXFSheet = oDrawing.Sheets.Add(DrawingSheetSizeEnum.kA0DrawingSheetSize, PageOrientationTypeEnum.kLandscapePageOrientation, "DXF")
'Set oDXFSheet = oDrawing.ActiveSheet
'DXFSheet.name = "DXF"
Dim oUserProps As PropertySet
Set oUserProps = oDoc.PropertySets.Item("User Defined Properties")
Dim oTG As TransientGeometry
Set oTG = oApp.TransientGeometry
Set oPoint = oTG.CreatePoint2d(0, 0)
Dim blnHasFlat As Boolean
Dim oPartProps As PropertySets
Dim dblSheetWidth As Double
Dim dblSheetHeight As Double
Dim oOcc As ComponentOccurrence
Set oBOMView = oDoc.ComponentDefinition.BOM.BOMViews.Item("Parts Only")
'Set oBOMView = oDoc.ComponentDefinition.BOM.BOMViews.Item("Structured")
Dim i As Integer
i = 1
Dim dblViewOffset As Double
dblViewOffset = 5
'get ipt
If oBOMRow.ComponentDefinitions.Item(1).Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
Set oPartDoc = oBOMRow.ComponentDefinitions.Item(1).Document
Set oPartProps = oPartDoc.PropertySets 'you can get iproperty values to textboxes also
If oPartDoc.ComponentDefinition.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then 'if you have controlling custom property that tells if dxf-view should be created put it also to this line with "AND"
If oPartDoc.ComponentDefinition.HasFlatPattern = True Then
'create drawing view
Set oBaseViewOptions = oApp.TransientObjects.CreateNameValueMap
Call oBaseViewOptions.Add("SheetMetalFoldedModel", False)
Set oView = oDXFSheet.DrawingViews.AddBaseView(oPartDoc, oPoint, 1, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, , , oBaseViewOptions)
'move view to new position
Dim newPos As Point2d
If i > 1 Then
Set newPos = oTG.CreatePoint2d(oDXFSheet.DrawingViews.Item(i - 1).Position.X + oDXFSheet.DrawingViews.Item(i - 1).Width / 2 + oView.Width / 2 + dblViewOffset, oDXFSheet.DrawingViews.Item(i).Height / 2 + dblViewOffset / 2)
oView.Position = newPos
'dblSheetWidth = dblSheetWidth + oDXFSheet.DrawingViews.Item(i).Width + dblViewOffset
ElseIf i = 1 Then
Set newPos = oTG.CreatePoint2d(oDXFSheet.DrawingViews.Item(i).Width / 2 + dblViewOffset / 2, oDXFSheet.DrawingViews.Item(i).Height / 2 + dblViewOffset / 2)
'create text boxes for part info
Dim strPartnum As String
Dim strMaterial As String
Dim strItemQTY As String
strPartnum = "Part Number: " & oBOMRow.ItemNumber 'normally balloon value
strMaterial = "Material: " & oPartDoc.ComponentDefinition.Material.name
strItemQTY = "Item Quantity:" & oBOMRow.ItemQuantity & "Pcs"
'Add info to sheet
Dim oText1 As Inventor.GeneralNote
Dim oText2 As Inventor.GeneralNote
Dim oText3 As Inventor.GeneralNote
Dim oTxtPoint1 As Point2d
Dim oTxtPoint2 As Point2d
Dim oTxtPoint3 As Point2d
Dim dblOffset As Double
dblOffset = 1
Set oTxtPoint1 = oTG.CreatePoint2d(oView.Position.X, (oView.Position.Y - oView.Height / 2 - dblOffset))
Set oText1 = oDXFSheet.DrawingNotes.GeneralNotes.AddFitted(oTxtPoint1, strPartnum)
Set oTxtPoint2 = oTG.CreatePoint2d(oTxtPoint1.X, (oTxtPoint1.Y - dblOffset))
Set oText2 = oDXFSheet.DrawingNotes.GeneralNotes.AddFitted(oTxtPoint2, strMaterial)
Set oTxtPoint3 = oTG.CreatePoint2d(oTxtPoint2.X, (oTxtPoint2.Y - dblOffset))
Set oText3 = oDXFSheet.DrawingNotes.GeneralNotes.AddFitted(oTxtPoint3, strItemQTY)
i = i + 1
Next
'save dxf
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn
Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDrawing, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\DXF_test.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
'Set the destination file name
oDataMedium.filename = "c:\tempdxfout.dxf"
'Publish document.
Call DXFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
End Sub
Message 11 of 22
tolgay.hickiran
Hey Risto, i managed to start your code but it stops at the last line
Do you happen to know what might be the problem? Cheers
Tolgay Hickiran
Founding Partner
SignatureSignature
website
Message 12 of 22
Did you copy the dxftest.ini file to c:? That is dxf configuration file.
Message 13 of 22
tolgay.hickiran
Yes i did indeed, i will try using it tomorrow again
Tolgay Hickiran
Founding Partner
SignatureSignature
website
Message 14 of 22
tolgay.hickiran
Hey risto,
USE CUSTOMIZE=Yes
CUSTOMIZE FILE=C:\Vault\Templates\Inventor Design Data\DWG-DXF\FlatPattern.xml
I changed this bit to USE CUSTOMIZE=No and remove the row below it worked.
Do you know any way to get Flat Pattern of a part without opening it?
Tolgay Hickiran
Founding Partner
SignatureSignature
website
Message 15 of 22
OK, good that you figured it out. I uploaded wrong ini-file. I had one with CUSTOMIZE=NO.
You can make the flat pattern with snippet below. This will change the part to sheet metal if normal part and do unfold. Thickness must be correct in sheet metal defaults.
'create flat pattern
'oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" 'use this if you need to convert normal parts to sheet metal
'Create Sheet Metal definition
Dim oSM As SheetMetalComponentDefinition
Set oSM = oDoc.ComponentDefinition
'oSM.UseSheetMetalStyleThickness = False
'oSM.Thickness.Expression="??" 'you can set thickness here if ipt is converted from normal part to sheet metal. I think you have the correct thickness in parameters or iproperties. You can put here parameter name if you have parameter for thickness in model.
Call oSM.Unfold
Message 16 of 22
tolgay.hickiran
See this is the thing Risto,
This routine requires the part to be opened in inventor, what i'm asking is just by opening the assembly can we get a flat pattern of a part. There are couple of apps on autodesk exchange that can do this work.
Tolgay Hickiran
Founding Partner
SignatureSignature
website
Message 17 of 22
I just gave you the way you can do it for ipt. You can make a loop that iterates through all components in assembly(iam) and does that routine for each component. You can also make a macro that creates flat patterns for selected components for example, just need to now how you wan't it to work.
Is your plan to use this together with flat pattern dxf export? If it is, you can add that snippet inside the flat pattern export macro. Here is flat pattern creation added to dxf export code. So this will make flat pattern for sheet metal parts that has no flat pattern before creating the view. Is this what you need?
Dim i As Integer
i = 1
dblViewOffset = 5
'get ipt
If oPartDoc.ComponentDefinition.HasFlatPattern = False Then
Set oSM = oPartDoc.ComponentDefinition
Call oSM.Unfold
If i > 1 Then
ElseIf i = 1 Then
'Add info to sheet
dblOffset = 1
i = i + 1
Next
'save dxf
'Publish document.
Message 18 of 22
tolgay.hickiran
RAS
What we are trying to do is to create flat patterns without opening parts one by one, we have a similar code structure like you posted and it does open the parts one by one and gets their flat pattern.
There is one particular program Dxf exporter on autodesk exchange which doesn't rely on opening parts inside an assembly one by one, thus it takes a really small time to create dxfs while having no flat patterns of the parts at the begining.
We are trying to achieve, getting these dxf files in say "10" seconds. (for around 200-300 unique parts that is). You could check the app on exchange, it is free for 30 days and you'll get what i mean.
Tolgay Hickiran
Founding Partner
SignatureSignature
website
Message 19 of 22
That code I pasted last does that in same time when exporting the dxf. It creates flat pattern if not exist.
Actually it does the same tricks than the dxf exporter(I tried that) except my code put all parts to same file, it can be exported also to each part to own sheet. File must be opened(at least in back round) to create flat patterns, but I think you mean you don't wan't open them one by one manually.
Btw. Why don't you buy that app because it seems to work quite nice.
Message 20 of 22
tolgay.hickiran
If we had a rush i'd say we buy it but we don't. The challange here is to make an app as good as that one, we are working on that 🙂
Tolgay Hickiran
Founding Partner
SignatureSignature
website
