Config File for Addin
bradeneuropeArthur
Mentor Mentor
Message 1 of 8
bradeneuropeArthur
How can I use a the App.config file in the add-ins created.
I don't want to use the User.config file of Inventor which is per default used. I want to use a config file per add-in.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (7)
Message 2 of 8
Frederick_Law
VS2022 Community
When I go to Settings and create one, it use app.config.
After build it'll use addin name.
Change Scope in setting:
Message 3 of 8
Michael.Navara
I don't use built-in configuration but my own. It gives you full control on it. You can store configuration in any format (XML, JSON, Registry, ...) in any location (local file per computer, ...per user, shared server, external database, etc.).
Implementation is relatively simple. You can see this project (configuration class, config manager, initialization)for more info.
Message 4 of 8
bradeneuropeArthur
Hi @Frederick_Law
did you rename the config file because in situation it is not using the App.Config file!
could you show what is copied to the add-in folder location?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
Frederick_Law
I did not rename it.  It'll rename after build.  It'll show "addinname".config.
Message 6 of 8
bradeneuropeArthur
For my case it does not take the config file.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
Frederick_Law
Hmmm my scope is "User".
Message 8 of 8
bradeneuropeArthur
What I try to achieve is that when I change the Local *.config file(in the add-in folder) that these settings is than used in the add-in.
Example:
I have a msgbox showing the following msgbox (my.settings.Name)
"Name is the setting with the string value "Banana"
when I change the *.config file locally after built and copying the files locally in the local file to "Name" ="Appel"
I want to show the msgbox result as "Appel"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
