How to add a baseview to a drawing
leebrg
leebrg
I wrote a code to open a drawing and add a view using i-logic code.
The code is as follows, and when I run the rule, an error occurs saying that the parameters are wrong, and the view is not created.
Can someone help me solve this problem?
        Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim docName As String = ThisDoc.FileName
	Dim oSheet As Inventor.Sheet = oDoc.ActiveSheet
	Dim modelpath As String = "C:\Temp\CYLINDER.iam"
	Dim oModel As Document = ThisApplication.Documents.Open(modelpath, False)
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim point As Point2d = oTG.CreatePoint2d(50, 50)
	Dim scale As Double = 1
	Dim oBaseView As DrawingView
	oBaseView = oSheet.DrawingViews.AddBaseView(oModel, point, scale, ViewOrientationTypeEnum.kTopViewOrientation, DrawingViewStyleEnum.kFromBaseDrawingViewStyl
Curtis_Waguespack
@leebrg , the ViewStyleEnum for a base view can not be set to kFromBaseDrawingViewStyle, as that is trying to pull the style from the base view from which the view being added is based on. Since you're adding a base view, it will not be based on any other view. See this version that sets the style to no hidden lines.
Hope this helps,
Curtis
	DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
leebrg
Thank you so much for your help.!!
