ComboBox in Ribbon Panel with vb.net
Martin-Winkler-Consulting
Advisor Advisor
Message 1 of 13
Hi, iam trying to implement a ComboBox into a user defined additional Inventor Ribbon Panel. The ComboBox is shown in the panel with its entries. But iam not able to catch the selected entry when it is clicked.
I implemented the Combobox in the AddinServer Class with
Public WithEvents comboBox1 As ComboBoxDefinition
'Definition ComboBox
comboBox1 = AddinGlobal.InventorApp.CommandManager.ControlDefinitions.AddComboBoxDefinition(
                        My.Resources.Browsernamen_wiederherstellen,
                        My.Resources.BrowserNameUpdate,
                        CommandTypesEnum.kQueryOnlyCmdType,
                        400, Guid.NewGuid().ToString(),
                        "Browsernanmen wiederherstellen", "Stellt den ursprünglichen Display Namen der zugehörigen Datei wieder her",
                        ButtonDisplayEnum.kDisplayTextInLearningMode)
                    comboBox1.AddItem(My.Resources.Alle_Browsernamen_wiederherste)
                    comboBox1.AddItem(My.Resources.selektierte_Browsernamen_wiede)
                    comboBox1.AddItem("ComboBoxItem #3")
                    comboBox1.DescriptionText = My.Resources.Browsernamen_wieder_herstellen
                    comboBox1.ListIndex = 2
 'Add it to the Browser Panel
 'Buttons in Ribbon Panel Browser hinzufügen (Tab "Browser")
                            AddinGlobal.RibbonPanel3DCSBrowserId = "{D2554A9F-2EEB-477B-A469-D40FBE606866}" 'MLHIDE
                            AddinGlobal.RibbonPanel3DCSBrowser = tabBrowser.RibbonPanels.Add(My.Resources.Browser_Panel, "GeneralTools_3DCS_AddIn.RibbonPanel_" & Guid.NewGuid().ToString(), AddinGlobal.RibbonPanel3DCSBrowserId, String.Empty, True) 'MLHIDE
                            Dim cmdCtrlsBrowser As CommandControls = AddinGlobal.RibbonPanel3DCSBrowser.CommandControls
                            cmdCtrlsBrowser.AddComboBox(comboBox1)
When i try to sent the OnSelect Event from AddIn class to my class ButtonActions i couldn't catch the NameValueMap
AddHandler comboBox1.OnSelect, AddressOf ButtonActions.ComboBox1_Execute3
With Buttons it works fine but there is no NameValueMap, for example:
buttonPart5.Execute = AddressOf ButtonActions.buttonPart5_Execute
Did anyone has an idea in which way i have to handle the OnSelect event and receiving the selected Index of the ComboBox from the NameValueMap?
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Replies (12)
Message 2 of 13
bradeneuropeArthur
Private Sub ComboBox1_OnSelect(Context As NameValueMap) Handles ComboBox1.OnSelect
            MsgBox(Context.Text)
        End Sub
    End Class
Add this to your code and remove the handler...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
Thanks at @bradeneuropeArthur
i tried it, but the Context is empty.
fires an exception because there is Nothing.
Is the AddinServer the correct place monitoring the event object?
Martin Winkler
CAD Developer
Message 4 of 13
you wrote Msgbox ("event handler")
For me the code worked fine I have tested...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 13
bradeneuropeArthur
this is needed
        End Sub
    End Class
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 13
This is the Result here using Context.Text:
Martin Winkler
CAD Developer
Message 7 of 13
What inventor version are you using?
what framework do you use?
What references are missing?
the code works fine by my add ins!!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 13
Inventor 2018
Visual Studio Community 2017
I think references are fine, all other stuff works
I will try it in another test project and with VS 2015
Martin Winkler
CAD Developer
Message 9 of 13
VS 2017 is not supported.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 13
bradeneuropeArthur
I use VS 2015, because of issues with VS 2017.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 13
Smiley Frustrated
same with VS2015. There has to be another reason.
Martin Winkler
CAD Developer
Message 12 of 13
Try to Use a different framework....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 13
@bradeneuropeArthur
thanks for your help and your solution. It was a good inspiration.
I made a workarround and could get this version which works properly in my AddinServer Class
First i declared comboBox1 as Public with Events
Public Class FreeTools_3DCS
    Implements Inventor.ApplicationAddInServer
then defined it and AddHandler to a Sub ComboBox1_OnSelect() in the same Addin Server Class
'Combo Box Definitions
                        "Value1", "Value2", CommandTypesEnum.kQueryOnlyCmdType,
                comboBox1.AddItem("Value1")
                comboBox1.AddItem("Value2")
                comboBox1.DescriptionText = "Test ComboBox"
                comboBox1.ListIndex = 1
                AddHandler comboBox1.OnSelect, AddressOf ComboBox1_OnSelect
then got it in this Sub
Private Sub ComboBox1_OnSelect()
 MsgBox(comboBox1.Text & " - " & comboBox1.ListIndex.ToString)
End Sub
and here is the result:
Martin Winkler
CAD Developer
