Check if part is on workspace if not then download from vault (iLogic)
KenVaessen
Message 1 of 12
KenVaessen
Is there an iLogic code that I can implement that checks if a part is on my workspace. If not then download this file from the vault
Replies (11)
Message 2 of 12
bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim CmdMan As ControlDefinition
    Set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckout")
    If CmdMan.Enabled = True Then
    CmdMan.Execute
        'CmdMan.Execute2 (True)
    End If
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
bradeneuropeArthur
Modified the last post....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 12
KenVaessen
I got the next error when I run this rule in iLogic:
Rule Compile Errors in Rule0, in afvoerbuis test samenstelling.iam
Error on Line 4 : Let- en Set-assignment instructions are no longer supported.
Error on Line 7 : Let- en Set-assignment instructions are no longer supported.
Message 5 of 12
bradeneuropeArthur
Public Sub main()
 a = ThisApplication
CmdMan.Execute 'CmdMan.Execute2 (True)
End If
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 12
KenVaessen
I've deleted the part in my workspace and runned the rule you wrote.
But he doesn't download the file from the vault (see attachment).
Message 7 of 12
bradeneuropeArthur
Set you project to straight VBA code
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 12
KenVaessen
How do I do that exactly?
Message 9 of 12
bradeneuropeArthur
Is your Vault activated within inventor?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 12
KenVaessen
yes it's active
Message 11 of 12
bradeneuropeArthur
try it in a different way:
For VBA:
Public Sub main()
set a = ThisApplication
set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckoutTop")
MsgBox "will be checked out"
End If
End Sub
For I logic
Public Sub Main()
a = ThisApplication
MsgBox ("will be checked out")
End If
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 12
KenVaessen
Still doesn't work. So I've  checked the assy out of the vault. I saved the assy to my workspace and all the parts are in the directory. Now I start the assy out of my workspace and I delete a part in this directory on the workspace. If I run the rule the part doesn't return in my workspace directory.
