Hello Everybody
I need some help how to achieve this in ilogic.
I would like to be able to check and see if excel is already open. Check that the excel application is running.
If the excel application is open, it willl be an unsaved workbook, created by a previous rule.
I have spent some time looking through the forums and VB.Net forums but i havent had any luck yet. The closest threads that I could find are below, but I couldnt get them to work.
https://forums.autodesk.com/t5/inventor-customization/code-to-check-if-a-file-is-open/td-p/5432055
https://www.vbforums.com/showthread.php?842295-Check-to-if-Excel-is-open-and-then-close-it
https://stackoverflow.com/questions/51770013/get-running-instances-of-excel-with-vb-net
https://stackoverflow.com/questions/9373082/detect-whether-excel-workbook-is-already-open
Is there a simple way to do this? I dont know my way around VB.Net code very well, and still learning on the ilogic too.
Appreciate any help.
