Check if excel application is running
william
william
Hello Everybody
I need some help how to achieve this in ilogic.
I would like to be able to check and see if excel is already open. Check that the excel application is running.
If the excel application is open, it willl be an unsaved workbook, created by a previous rule.
I have spent some time looking through the forums and VB.Net forums but i havent had any luck yet. The closest threads that I could find are below, but I couldnt get them to work.
https://forums.autodesk.com/t5/inventor-customization/code-to-check-if-a-file-is-open/td-p/5432055
https://www.vbforums.com/showthread.php?842295-Check-to-if-Excel-is-open-and-then-close-it
https://stackoverflow.com/questions/51770013/get-running-instances-of-excel-with-vb-net
https://stackoverflow.com/questions/9373082/detect-whether-excel-workbook-is-already-open
Is there a simple way to do this? I dont know my way around VB.Net code very well, and still learning on the ilogic too.
Appreciate any help.
bradeneuropeArthur
 Try
            For Each p In Process.GetProcesses
                If p.ProcessName = "EXCEL" Then
                        p.Kill()
                        BolExcelRunning = False
                    End If
                End If
            Next
        Catch ex As Exception
        End Try
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
william
Thanks @bradeneuropeArthur
I modified it slightly to what I wanted and it works great.
Try
			ExcelRunning = True
			MessageBox.Show("Excel is running", "Title")
		End If
	Next
End Try
If ExcelRunning = False Then
	MessageBox.Show("Excel is not running", "Title")
End If
