Check if drawings needs migrating
w.pepping
w.pepping
I have an add in to make a copy design.
In Inventor the active design is first checked if all files are migrated to the current release because I do the copy design with apprentice.
In Apprentice it is not possible to migrate.
The issue is that if I do a check for migrating drawings, the answer is always false, even if the drawing is saved in an older version. For ipt and iam files it works correct.
I use this code:
    Dim doc As Document
    Set doc = ThisApplication.ActiveDocument
MsgBox (doc.NeedsMigrating)
How can I detect if a drawing needs to be migrated for further use in Apprentice?
Get control of your sheet metal files.
Download the app from matprop.com
JaneFan
Hello @w.pepping
Seems there is something not working well in DrawingDocument.NeedsMigrating. Please use this code as a work around:
If Not oDoc.SoftwareVersionSaved.DisplayVersion = ThisApplication.SoftwareVersion.DisplayVersion Then
Msgbox("Document.NeedsMigrating is True")
Jane Fan
Inventor/Fusion QA Engineer
bradeneuropeArthur
@w.pepping
Please use a specific declaration  for the drawingdocument.
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
MsgBox b.NeedsMigrating
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
w.pepping
The specific declaration does not the trick. Result is still NO for all drawing files.
The answer of JaneFan is a good work around. Only thing to be aware of is the service pack number since Inventor 2017.
If a part has a DisplayVersion of 2017.1 you do not want to migrate it to 2017.2. Another thing is that it is possible to open a 2018 document in 2017. For that situation you need an extra check.
salariua
Thanks @JaneFan
@w.pepping is right, I had a case where 2018.1  reported as needs migrating to 2018.2
checking just first 4 digits and avoiding files created with newer Inventor. My case avoiding files from 2019, 2020...
If Left(oDoc.SoftwareVersionSaved.DisplayVersion,4) < Left(ThisApplication.SoftwareVersion.DisplayVersion,4) Then
   MsgBox("NeedsMigrating")
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
