Adding a custom drawing property
larry_dubroff
larry_dubroff
I'm creating customized drawing formats for the engineering staff. I'd like to have the author's email address to be added automatically to the title block. Since the email address does exist as part of the user ID how do I add that to the properties-drawing pull down menu?
thanks...larry dubroff
bradeneuropeArthur
What do you mean with properties drawing pull down menu?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
larry_dubroff
in the format text dialog box the pull down option of "properties - drawing" then gives me a bunch of pre-set properties. I'd like to add the user's email address as a custom property to that list.
bradeneuropeArthur
Ok I understand.
I will take a look.
Maybe you could already use the emailadress iproperty!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
You cannot add properties to the predefined property-sets of inventor.
The only possible way is adding a custom I-property with the emailadress.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
