Changing Mark Style
Changing Mark Style
brianA32ZM
Changing Mark Style
brianA32ZM
Hello, I am attempting to change the Style of a Mark located on a sheet metal flat pattern. The code below fails at  "oMarkDef.Style.name = "Mark Surface" and I am not sure why. Can someone help point me in the correct direction. Thank you.
' Create a new part document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
For Each oMarkDef In oCompDef.Flatpattern.Features.item("Etch Info").definition
Next
error:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateSet(Object o, Type& objType, String name, Object[] args, String[] paramnames, Boolean OptimisticSet, CallType UseCallType)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase, CallType CallType)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSetComplex(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase)
bradeneuropeArthur
Could you share the files?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
brianA32ZM
Thank you, the test file is attached.
JelteDeJong
try this:
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
oCompDef.FlatPattern.Edit()
Dim oMarkDef As MarkDefinition = oCompDef.Flatpattern.Features.item("Etch Info").definition
Dim style = oPartDoc.MarkStyles.Item("Mark Surface")
For i As Integer = 1 To oMarkDef.MarkGeometrySetCount
	oMarkDef.MarkGeometrySetItem(i).Style = style
Next
Jelte de Jong
Blog: hjalte.nl - github.com
brianA32ZM
JelteDeLong,
Thank you so much. I sent hours trying to solve that one. It is frustrating as I did find MarkGeometrySet in the programming help but could not figure out how to apply it. Thanks again!
