Changing iPart with iLogic
Nauld1
Nauld1
So I wrote the Following iLogic:
If Crosstie_Depth = True And UG_Height = 132 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-01")
If Crosstie_Depth = True And UG_Height = 168 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-05")
If Crosstie_Depth = True And UG_Height = 192 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-09")
If Crosstie_Depth = False And UG_Height = 132 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-03")
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-07")
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-11")
It's supposed to change the height of a post and the spacing of holes on the post based on set parameters. There doesn't seem to be any errors with the program itself, but when I change my parameters the iPart won't change. Anyone have any ideas why?
Nauld1
If Crosstie_Depth = False And UG_Height = 168 in Then
If Crosstie_Depth = False And UG_Height = 192 in Then
 Sorry this is the actual iLogic
tolgay.hickiran
Try to do the list with SELECT CASE rather then If then end if
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
HermJan.Otterman
It should work but only one time. After that the name in the browser has changed??. You first need to change the name in the browser to for example "ML2005-5" put this also in your code. And use only one if then ELSE. Put in front of the second and following if's "else" and remove all the "end if" except for the last one..
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
