Changing iPart with iLogic
Nauld1
Message 1 of 1
Nauld1
So I wrote the Following iLogic:
SyntaxEditor Code Snippet
If Crosstie_Depth = True And UG_Height = 132 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-01")
If Crosstie_Depth = True And UG_Height = 168 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-05")
If Crosstie_Depth = True And UG_Height = 192 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-09")
If Crosstie_Depth = False And UG_Height = 132 in Then
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-03")
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-07")
iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-11")
It's supposed to change the height of a post and the spacing of holes on the post based on set parameters. There doesn't seem to be any errors with the program itself, but when I change my parameters the iPart won't change. Anyone have any ideas why?
Replies (0)
