Changing iPart with iLogic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I wrote the Following iLogic:
If Crosstie_Depth = True And UG_Height = 132 in Then iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-01") End If If Crosstie_Depth = True And UG_Height = 168 in Then iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-05") End If If Crosstie_Depth = True And UG_Height = 192 in Then iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-09") End If If Crosstie_Depth = False And UG_Height = 132 in Then iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-03") End If If Crosstie_Depth = True And UG_Height = 168 in Then iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-07") End If If Crosstie_Depth = True And UG_Height = 192 in Then iPart.ChangeRow("ML2005_iAssembly:5", "ML2005_iAssembly-11") End If
It's supposed to change the height of a post and the spacing of holes on the post based on set parameters. There doesn't seem to be any errors with the program itself, but when I change my parameters the iPart won't change. Anyone have any ideas why?
