Changing flush constraint offset with VB.NET
keithjk
keithjk
I want to be able to to change the offset of my flush constraints.  The code below is a start.  I can retrieve the current offset values of my two constraints and then post them to a text box.  But I cannot figure out how to send the data back from the text box when the user changes it.
Dim selSet As SelectSet
selSet = oAssemblyDocument.SelectSet
Dim selSetCount As Integer = 0
selSetCount = selSet.Count
If selSetCount = Nothing Or selSetCount = 0 Then
Beep()
MsgBox("You must select component(s) first.", vbOKOnly, "Error Selecting Components")
Else
If TypeOf selSet.Item(1) Is ComponentOccurrence Then
oOcc = selSet.Item(1)
'are there existing constraints?
If oOcc.Constraints.Count > 0 Then
For j = 1 To oOcc.Constraints.Count
'is there a mating constraint?
If UCase(oOcc.Constraints.Item(j).Name).Contains("FLUSH") = True Then
If j = 1 Then
Constraint1 = oOcc.Constraints.Item(j)
txtOffset1.Text = Math.Round((Constraint1.Offset.Value), 4)
If j = 2 Then
Constraint2 = oOcc.Constraints.Item(j)
txtOffset2.Text = Math.Round((Constraint2.Offset.Value), 4)
Next j
xiaodong_liang
Autodesk Support
Autodesk Support
Offset is an object Parameter. you can set its value by Offset.Value =  <new value>.
hope it helps.
keithjk
Xiaodong,
Thanks for the response.  My problem was that I failed to place ".value" after offset when I was trying to change it.  Now I have a new problem in that even though I can set the offset value, it does not update the componet in the assembly.
For testing purposes, I am trying to add or subtract 0.75 units in the code below.  It accepts the new offset values now but it does not move the component.  And if I look at the properties of the constraint offset in Inventor (see attached) it isn't updating it.  To me it looks like I am not obtaining or setting the correct offset parameter?? (If that makes sense.).  I have verified that that I am trying to change the correct constraint.  I have also verfied that the component is not grounded.
Thanks for the help.  I am new to programming in Inventor.
Keith
Private Sub btnChangeComp_Click(sender As Object, e As EventArgs) Handles btnChangeComp.Click
Beep()
Else
If j = 1 Then
' /////////// this is just for testing ///////////////////
Constraint1.Offset.Value = Constraint1.Offset.Value - 0.75
If j = 2 Then
Constraint2.Offset.Value = Constraint2.Offset.Value + 0.75
Next j
End Sub
MechMachineMan
Have you tried simply updating/rebuilding the model after you change it?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
keithjk
updating the assembly did it!
Thanks!!!
MechMachineMan
oAssemblyDocument.Update should work perfect to accomplish that in your program.
Justin K
xiaodong_liang
Autodesk Support
Autodesk Support
Hi keithjk,
I just got time to get back, while it looks Justin has helped you 🙂 I marked it as the solution.
