I'm trying to quickly format parameters in parts with an external iLogic script from the assembly level.
I can run this script at the part level
Imports Inventor.UnitsTypeEnum Dim oParams As Parameters oParams=ThisDoc.Document.ComponentDefinition.Parameters Dim oUserParams As UserParameters oUserParams=oParams.UserParameters 'Look for Frame Gen Parameter and format it Try Dim oParam As Parameter 'Enter the name of Paramter here Dim MyParam As String = "G_L" oParam = oUserParams(MyParam) oParam.ExposedAsProperty = True 'format Custom Parameter Dim oFormat As CustomPropertyFormat oFormat = oUserParams(MyParam).CustomPropertyFormat oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Units="ft" oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision oFormat.ShowUnitsString = False oFormat.ShowLeadingZeros = False oFormat.ShowTrailingZeros = False Catch End Try
But when i add it to other scripts i've found to run from the Assembly level nothing happens....
Imports Inventor.UnitsTypeEnum Dim openDoc As Document openDoc = ThisDoc.Document Dim docFile As Document If openDoc.DocumentType = 12291 Then For Each docFile In openDoc.AllReferencedDocuments If docFile.DocumentType = 12290 Then Dim oParams As Parameters oParams=ThisDoc.Document.ComponentDefinition.Parameters Dim oUserParams As UserParameters oUserParams=oParams.UserParameters 'Look for Frame Gen Parameter and format it Try Dim oParam As Parameter 'Enter the name of Paramter here Dim MyParam As String = "G_L" oParam = oUserParams(MyParam) oParam.ExposedAsProperty = True 'format Custom Parameter Dim oFormat As CustomPropertyFormat oFormat = oUserParams(MyParam).CustomPropertyFormat oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Units="ft" oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision oFormat.ShowUnitsString = False oFormat.ShowLeadingZeros = False oFormat.ShowTrailingZeros = False Catch End Try End If Next Else MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If
Any ideas?
thanks!!!
