Change Material with vb.net doesen't work
Hi all,
I'm trying to set automaticly the Material in a mirrored sheetmetalpart. I whrote a VBA-code like:
Dim orefMat As String
orefMat = orefdoc.ComponentDefinition.Material.Name
Dim oMaterial As Material
Set oMaterial = odoc.Materials.Item(orefMat)
ocompdef.Material = oMaterial
this code worked. Now the next step is coding in vb.net and VisualStudio 2017.
I've tried the same method "ocompdef.Material = oMaterial" but in VS this doesen't work. In debugging-mode I got the message: Member not not found.
Thanks for helping
Greatings
Steffen
HideoYamada
Hello Steffen,
Use Material Assets instead of Materials.
This code works in VBA and will work VB.net.
Sub test()
    Dim partDoc As PartDocument
    Dim refDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    Set refDoc = partDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1).ReferencedDocumentDescriptor.ReferencedDocument
    Dim newMaterialAsset As MaterialAsset
    ' This line will fail when the material asset already exists in partDoc.
    Set newMaterialAsset = refDoc.ActiveMaterial.CopyTo(partDoc)
    partDoc.ActiveMaterial = newMaterialAsset
End Sub
Open the part document which contains the derived part (mirror derived part), and run this.
Best regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
bradeneuropeArthur
Try this:
 Dim oInvActPartDoc As Inventor.PartDocument '= Nothing
        oInvActPartDoc = m_InventorApplication.ActiveDocument
        If Not oInvActPartDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
            Exit Sub
        End If
        If Not oInvActPartDoc.ComponentDefinition.Material.Name = oInvActPartDoc.Materials.Item(orefMat).Name Then
            oInvActPartDoc.ComponentDefinition.Material = oInvActPartDoc.Materials.Item(orefMat)
        End If
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thanks, I found the error🤐
Many thanks for the quick response.
Greatings
Steffen
