Change Material and copy
GeorgK
Advisor Advisor
GeorgK
Hello together,
whats the best way to change the material in a part? I use this code for VB.Net:
oDoc.ComponentDefinition.Material = oDoc.Materials.Item("Titanium")
Is there a better way and more stable for Inventor 2014-2016?
How could I copy materials from one library to another one?
Thank you Georg
MechMachineMan
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
adam.nagy
Autodesk Support
Autodesk Support
Hi Georg,
Have just written an article on copying material:
http://adndevblog.typepad.com/manufacturing/2015/05/copy-material-to-another-library.html
Cheers,
Adam Nagy
Autodesk Platform Services
GeorgK
Hello Adam,
thanks for the solution.
Cheers
Georg
