Centre of Gravity in Assembly
Hello everyone,
In Inventor, a component has 2 Centre of Gravity Co-ordinates
1. Along its own origin
2. Along the origin of the assembly in which it is placed.
I have a code that allows me to extract the CG values in BOM for the point 1 (with respect to part origin).
Is there any snippet or code that would allow to extract the values taking point 2 into consideration i.e. assembly specific values.
Thanks in advance
Regards
Aman
bradeneuropeArthur
with this
For Vba:
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Dim c As AssemblyComponentDefinition
Set c = b.ComponentDefinition
'c.MassProperties.CenterOfMass.X
'c.MassProperties.CenterOfMass.Y
Dim cogX As String
cogX = c.MassProperties.CenterOfMass.X
Dim cogY As String
cogY = c.MassProperties.CenterOfMass.Y
'Dim cogXprop As Property
Call b.PropertySets.Item(4).Add(cogX, "CogX")
Call b.PropertySets.Item(4).Add(cogY, "CogY")
End Sub
 For I-Logic:
Public Sub main()
 a = ThisApplication
Dim cogX As String
Dim cogY As String
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
@bradeneuropeArthur  Firstly thanks for your response. However I was getting error in the call functions in both VBA as well as iLogics.
(Using Inventor 2017 version).
Your code works well for the top level assembly. However, could not get it work on the sub assemblies and underlying parts in the assembly.
I updated the code as below but still did not get any success. Could you help me where am I going wrong ?
Public Sub Main()
 a = ThisApplication
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In c.Occurrences.AllReferencedOccurrences(c)
Dim cogX As String
Dim cogY As String
Dim cogZ As String
cogZ = c.MassProperties.CenterOfMass.Z
'Call b.PropertySets.Item(4).Add(cogX, "CogX")
'Call b.PropertySets.Item(4).Add(cogY, "CogY")
iProperties.Value("Custom", "CG-X") = cogX
iProperties.Value("Custom", "CG-Y") = cogY
iProperties.Value("Custom", "CG-Z") = cogZ
Next
End Sub
hendrik.koopmans
Hey,
i used a part aof this code anbe because there was no final solution here is mine.
Public Sub Schwerpunkte(Zeile) 'Vector des Center
Dim FileName
FileName = "C:\Users\hendr\Documents\Aktuelles\Masterarbeit\VBA\GoGoGo\Datenablage.xlsx"
Dim ExcWb As Excel.Workbook
Set ExcWb = Workbooks.Open(FileName)
Dim cc As AssemblyComponentDefinition
Set cc = b.ComponentDefinition
Dim cogX As Double
Dim cogY As Double
Dim cogZ As Double
For Each oOccurrence In cc.Occurrences.AllReferencedOccurrences(cc)
If oOccurrence.Name = "Nuss:1" Then
cogX = oOccurrence.MassProperties.CenterOfMass.X
cogY = oOccurrence.MassProperties.CenterOfMass.Y
cogZ = oOccurrence.MassProperties.CenterOfMass.Z
ExcWb.Worksheets(2).Cells(Zeile, 41).Value = cogX
ExcWb.Worksheets(2).Cells(Zeile, 42).Value = cogY
ExcWb.Worksheets(2).Cells(Zeile, 43).Value = cogZ
cogX = 0
cogY = 0
cogZ = 0
If oOccurrence.Name = "Ratsche:10" Then
ExcWb.Worksheets(2).Cells(Zeile, 44).Value = cogX
ExcWb.Worksheets(2).Cells(Zeile, 45).Value = cogY
ExcWb.Worksheets(2).Cells(Zeile, 46).Value = cogZ
cogX = 0
cogY = 0
cogZ = 0
Next
ExcWb.Save
End Sub
