iLogic rule to change layers of specific parts of an assembly of a section view
viniciusfortes
viniciusfortes
Hello there,
Quite a mouthful, I know.
I have a big assembly which is sectioned vertically and horizontally, originating 2 section views.
On those views the part that are sectioned must have a black continous line and those who are not must assume a gray dashed line layer.
If the assembly "stood still" then it would a piece of cake, selecting edge priority and setting manually the desired layer. But since this is a parametric assembly it can assume sizer 5 times as big, so when i change the section line or break line I must every time change the layers for other parts.
Can anybody help me with this?
By the way, if someone algo knows how do i control section lines and break lines with a parameter it would really help as well.
chandra.shekar.g
Autodesk Support
Autodesk Support
@viniciusfortes,
Hoping that suggestion in the below link might be useful.
https://modthemachine.typepad.com/my_weblog/2010/10/changing-drawing-curves-to-match-assembly-color....
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
