Placing Sketch Symbol with Prompted Entry using iLogic
swalroth8KYHK
swalroth8KYHK
This is probably a stupid question, but I just can't get it working.
I'm trying to place a view label and fill out 4 Prompted Entries with information gathered from various sources.
Dim vNum As Integer
Dim sdNum As String
Dim fName As String
Dim oMaterial As String
'Dim sPromptString(3) As String
Dim sPromptString(0) As String
'Dim sPromptString As String()
'oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("Label - View - v2") oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("Label - Door/Window") 'sPromptString = {vNum, sdNum, fName, oMaterial} sPromptString = {"A"} 'MsgBox(sPromptString(0) & " - " & sPromptString(1) & " - " & sPromptString(2) & " - " & sPromptString(3), okay, "Debug") MsgBox(sPromptString(0), okay, "Debug") oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oPoint2, 0, 1, sPromptString)
I dropped it back to another label that has only one Prompted Entry to test, and it still won't fill it out.  If I pick a symbol with no Prompted Entries, and change it to Nothing, it works fine, but no matter what I try I keep getting an error:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
In both cases the Message Box shows all the information I want as expected, the first symbol "Label - View - v2" has 4 entries and the second "Label - Door/Window" has 1.
Sergio.D.Suárez
Here is an example with a sketch symbol insert with 4 entries.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oSymDef As SketchedSymbolDefinition = oDoc.SketchedSymbolDefinitions.Item("Label - Door/Window")
Dim sPromptStrings(3) As String
sPromptStrings(0) = "Value A"
sPromptStrings(1) = "Value B"
sPromptStrings(2) = "Value C"
sPromptStrings(3) = "Value D"
Dim oPosition As Point2d =  ThisApplication.TransientGeometry.CreatePoint2d(10,15)
Dim oSymbol As SketchedSymbol
oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings)
I hope it is useful for you. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
swalroth8KYHK
Your code works just fine, but for some reason I just cannot get mine to.  As far as I can tell this is exactly the same.
Dim fPath As String = ThisDoc.Path
Dim fNames() As String = System.IO.Directory.GetFiles(fPath, "*.ipt")
Dim fName As String
Dim pType As String
Dim sdNum As String
Dim StartTime = Now
Dim oPartDocPath As String
Dim oPartDoc As PartDocument
Dim oDrawDoc As DrawingDocument
Dim oSheet As Object
Dim oTG As TransientGeometry
Dim oPoint1 As Point2d
Dim oPoint2 As Point2d
Dim oBaseView As Object
Dim oViewModelDoc As Object
Dim oSketchedSymbolDef As SketchedSymbolDefinition
Dim oSketchedSymbol As SketchedSymbol
Dim xPos As Integer
Dim vNum As Integer
xPos = 5
vNum = 1
sdNum = iProperties.Value("Project", "Stock Number") & ".0"
For Each fName In fNames
fName = IO.Path.GetFileName(fName)
pType = Mid(fName, 11, 2)
If pType = "CB" Then
	oPartDocPath = fPath + "\" + fName
	oPartDoc = ThisApplication.Documents.Open(oPartDocPath, False)
	oDrawDoc = ThisDoc.Document
	oSheet = oDrawDoc.ActiveSheet
	oTG = ThisApplication.TransientGeometry
	oPoint1 = oTG.CreatePoint2d(xPos, - 50)
	oPoint2 = oTG.CreatePoint2d(xPos, - 80)
	oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 1 / 8, ViewOrientationTypeEnum.kIsoTopRightViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle, "Default")
	oPartDoc.Close
	oViewModelDoc = oBaseView.ReferencedDocumentDescriptor.ReferencedDocument
	oMaterial = oViewModelDoc.PropertySets.Item("Design Tracking Properties").Item("Material").Value
	xPos = xPos + 30
	sPromptString(0) = vNum
	sPromptString(1) = sdNum
	sPromptString(2) = fName
	sPromptString(3) = oMaterial
	vNum = vNum + 1
Next
Sergio.D.Suárez
The codes are not the same, at first impression the first visible error is that it has sized the sheet as an object.
Dim fName As String
Dim pType As String
Dim sdNum As String
Dim StartTime = Now
Dim xPos As Integer
Dim vNum As Integer
xPos = 5
vNum = 1
	oPartDoc.Close
	xPos = xPos + 30
	vNum = vNum + 1
Next
I do not have your files so I can not prove the complete code but I can show you that this simple code below works.
Dim oSheet As Sheet
oPoint2 = oTG.CreatePoint2d(10,8)
sPromptString(0) = "vNum"
sPromptString(1) = "sdNum"
sPromptString(2) = "fName"
sPromptString(3) = "oMaterial"
In the case of your punctual code, it may be the case that you have more errors that you should debug. If you know that a code sequence works, the error is probably somewhere else.
Here you have two other possible errors
They should be
Dim oBaseView As DrawingView
Dim oViewModelDoc As Document
regards
Mechanical Designer
swalroth8KYHK
I knew it would be something simple, thanks so much.  It works exactly as intended now.
Sergio.D.Suárez
A little advice that may be useful for you later.
When you believe that part of the code is OK, and you do not know the location of the error, try to insert a simple message box MessageBox.Show ("Message", "Title") of your ilogic, locate it at the beginning of the code. Execute the file, and if the box appears, the error will be lower. Now locate the message box and place it below in your program. Re-execute the code and perform this procedure until you find the possible place where the error is generated. Regards!
Mechanical Designer
swalroth8KYHK
To be fair, I had done as much with a message box immediately before the line adding the sketch symbol.  Everything else ran smoothly.  I was even able to place a symbol that had no prompted entries with the same code by changing only the symbol name.
