Cannot load an .IVB file -> Inventor replace it
Crstiano
Crstiano
I try to define a new .IVB file for Inventor Load when it starts. After applied on Application Options and Close the Inventor.
But when I ask to execute again.. the inventor load and replace the .IVB for a clean file.
Windows 10
Inventor 2019, no SP or Hotfix installed.
Suggestions?
Cristiano Oliveira
ConsultCAD.com
Frederick_Law
Can you open that IVB file in VBA Editor?
bradeneuropeArthur
Where is that file stored?
  • on your local drive?
  • on a network drive?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Crstiano
Thanks, you remember me this simple test...
The user using a corrupted file... after update for the original file, it works fine.
Why the IVB file after open load on VBA Editor asks to save again. And if save it, increase the size a lot !
Has anyone else noticed this?
Cristiano Oliveira
ConsultCAD.com
Crstiano
The case is resolved and in this case I try on both.
Cristiano Oliveira
ConsultCAD.com
Frederick_Law
Nope, I opened old 2015 IVB with IV2023 and it didn't ask to save.
