Setting the clipboard text sequentially
nbonnett-murphy
Message 1 of 10
nbonnett-murphy
I'm trying to push text to the clipboard 2 times in a row. I know it's an unusual thing to do, but I like to use the clipboard history feature of windows (start+v). So as part of a larger "fast info" script, I want to push the part description onto the clipboard, then as a separate operation, push the part number.
Here is what I have now:
Imports System.Windows.Forms
Clipboard
.SetText(ITEMPropertySet.Item("Description").Value)
Clipboard.SetText(ITEMPropertySet.Item("Part Number").Value)
The problem is that it only shows the part number in the clipboard history, which makes sense, since I set it then immediately over write it.
If I go like this:
Clipboard
msgbox("this is a message box")
Then both properties show up in the history. I'm gathering from this that the message box causes some sort of "go" or "update" or "execute" operation to happen that commits the clipboard text setting. Is there a way that I can force this to happen?
I had high hopes for system.windows.forms.application.DoEvents(), but that doesn't seem to work as expected.
Replies (9)
Message 2 of 10
Frederick_Law
https://learn.microsoft.com/en-us/dotnet/api/system.windows.clipboard.settext?view=windowsdesktop-7....
Try use a different Clipboard: system.windows.clipboard
instead of: system.windows.forms.clipboard
https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.clipboard.settext?view=windowsdesk...
This one clear clipboard before adding text
Message 3 of 10
nbonnett-murphy
I don't seem to have access to the system.windows.clipboard class, just the forms one. I get a "not a member" error if I leave out forms.
I think I see what you're saying though. By messing around with system.windows.forms.clipboard.clear and .settext, I'm gathering that it's the automatic clearing that's wiping out the data I want to see in the clipboard.
Is there some secret to getting at the system.windows namespace?
Message 4 of 10
Frederick_Law
I can't get to it in iLogic either.
Message 5 of 10
Frederick_Law
Found out how to add reference here:
https://github.com/koechlm/iLogic-Filter-Configurator/tree/master/WpfApp1
Add these to header:
AddReference "PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"
AddReference "PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"
Maybe only one of them is needed.
Somehow it made the rule "unsafe".
I did add text to clipboard.
Message 6 of 10
nbonnett-murphy
Eh, thanks for the help. It's not a critical thing and I spent too much time on it today anyways. I tried an ugly workaround by popping up the message box and then using sendkeys to hit the "enter" key, but I'm running into the same issue. The sendkeys doesn't fire until after the message box has been closed by the user.
I think there's some windows.forms message queueing situation that's above my head. Like I somehow need to open a thread, setText on the clipboard, close the thread, and then do that same operation again.
Edit: the AddReference you sent does give me access to that member of system.windows, but it still seems to be queuing commands in the same way.
Message 7 of 10
Frederick_Law
Interesting results:
Sub Main()
	System.Windows.Clipboard.SetText("abc")
	Logger.Info(System.Windows.Clipboard.GetText)
	System.Windows.Clipboard.Flush
	System.Windows.Clipboard.SetText("1234")
	System.Windows.Clipboard.SetText("abcde1234")
End Sub
They're in the clipboard but not in the clipboard 😵
Message 8 of 10
Frederick_Law
Got it.
This works:
imports System.Windows.Forms
Sub Main()
	System.Windows.Forms.Clipboard.SetText("abc")
	System.Threading.Thread.CurrentThread.Sleep(250)
	System.Windows.Forms.Clipboard.SetText("1234")
	System.Windows.Forms.Clipboard.SetText("abcde1234")
End Sub
Message 9 of 10
nbonnett-murphy
Awesome thanks!
I also tried to use "getText" between the sets but had, I assume, the same results that you did. I'm surprised that sleep works and I'd love to find out what exactly the trigger is to "lock it in".
Message 10 of 10
Frederick_Law
Saw it while searching about clipboard.
Sleep(200) didn't work.  You can test and find the lowest number that works.
