Can not extrude after import dwg to sketch
SandmanINV
SandmanINV
Hello everybody,
I have problem with using API to import dwg file then extrude them.
If I import that file to inventor sketch by hand, everything is OK, i can extrude immediately. But with that dwg file, if i using vbnet to import dwg file to inventor sketch,. Importing successful, but I can not extrude. I don't know why, pls help.
I attached my dwg for someone can use.
Thank you for reading my topic.
bradeneuropeArthur
Are you importing to  a new part?
Is this part saved before Import?
Is this part saved After Import?
  • Try a save after the import...
What version of inventor are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
