Can an iLogic Function return multiple parameters?
And if so, how?
If not, is there any good workaround?
I'm thinking shared parameters may not be a good solution since I'll be calling the function multiple times to modify different sets of parameters.
Sergio.D.Suárez
Hi, A simple method could be to take each parameter within the function and create a string with a specific dividing character, for example a "|", then return this string.
When this string is returned it could be divided with a "split" and take each parameter again to perform an action.
Here is an example of how to create a split
'Parameters
Dim p1 As Double = 5.3
Dim p2 As Double = 14.2
Dim p3 As Double = 515.8
Dim p4 As String = "Example"
Dim p5 As Double = - 8.8
Dim sep As String = "|"
'Create String
Dim oString As String = p1 & sep  & p2 & sep & p3 & sep & p4 & sep & p5
MessageBox.Show(oString)
'Split String
Words = oString.Split(sep)
'List all values
For Each wrd In Words
	MessageBox.Show(wrd)
Next
 I hope to be clear, greetings!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you!
I was hoping someone would prove me wrong, and there is a native way to return multiple parameters, but this approach gets the job done well! 😃
bradeneuropeArthur
Maybe this comes closer to your needs!
Public Sub main()
MsgBox x(o)
End Sub
Public Function x() As Variant
 x = Array("parameter1", "parameter2", "parameter3")
End Function
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JelteDeJong
just another option if you are using iLogic. You can use the posibility to ceate a class and use global variables.
Public Class ThisRule ' <-- This name is required
	Private para1 As String
	Private para2 As String
	Private para3 As String
	Public Sub Main() ' <-- This name is required
		subFunction()
		MsgBox(para1)
		MsgBox(para2)
		MsgBox(para3)
	End Sub
	Private Sub subFunction()
		para1 = "test1"
		para2 = "test2"
		para3 = "test3"
	End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
