C# Toolbar button not working on click
I been working on a C# addin for Inventor 2019. This addin creates a toolbar, which works, that has a single button. After registering a handler to the button, nothing happens when I click the button. Interestingly if I manually execute the button, that does what it should.
Note that I have generalized the code to remove certain information (ex. ClassToOpen is not the actual class name).
Any help is greatly appreciated, thanks.
public void Activate(ApplicationAddInSite addInSiteObject, bool firstTime) {
// General addin stuff
Application Inventor = addInSiteObject.Application;
var guid = $"{{{GuidAttribute.Value}}}"; // This is the GUID that is on the addin server attribute
// Button creation
ButtonDefinition command0 = Inventor.CommandManager.ControlDefinitions.AddButtonDefinition("Button 1", nameof(ClassToOpen), CommandTypesEnum.kFilePropertyEditCmdType, guid, "Display dialog", "Display dialog", PictureConverter.GetPicture(Properties.Resources.toolbar_buttons_16x16), PictureConverter.GetPicture(Properties.Resources.toolbar_buttons_24x24));
Command0_EventHandler = new ButtonDefinitionSink_OnExecuteEventHandler(Command0_OnExecute);
command0.OnExecute += Command0_EventHandler;
// This works, but clicking the button does not
command0.Execute();
private void Command0_OnExecute(NameValueMap Context) => ClassToOpen.OpenDialog();
        private ButtonDefinitionSink_OnExecuteEventHandler Command0_EventHandler;
bradeneuropeArthur
Where have you declared the CommandButton?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Aha! That was it, thank you.
Updated command0 from my sample to be a private class variable and all is well.
bradeneuropeArthur
Sometimes things are easy sometimes not.
Good luck further!
@Anonymous
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
