File Locked Prompt after copy design with ilogic
mark.almack
mark.almack
I'm using ilogic to copy a part like this:
oDoc = ThisApplication.Documents.Open(TemplatePart & ".ipt", False)
oDoc.SaveAs(NewName & ".ipt", False)
I want to then do something with the new file (e.g oDoc.Update), but when i do i get a prompt saying:
"'Newname.ipt' is currently locked. do you want to continue editing anyway? your changes will not get saved to the vault."
The new file is neither locked, nor is it in the vault!
Any ideas how i can get around this issue?
thanks
A.Acheson
Is the new file saved to a library folder which is read only? Is there a network involved as save location? Is the new name unique? Maybe try it on a new set of files not in vault!
Regards
Alan
mark.almack
Is the new file saved to a library folder which is read only? - No.
Is there a network involved as save location? - No.
Is the new name unique? - yes
Maybe try it on a new set of files not in vault! - well yes this works fine, but i need it to work on files that are in vault.
I've noticed the vault browser displays the old filename greyed out and crossed out too. It's getting confused for some reason?!?
Regards
Mark
Curtis_Waguespack
Hi @mark.almack
My guess would be that the file you are opening is one that is used in an assembly that is loaded into memory... so what is happening is the assembly is seeing the file get dirtied, and things are getting a bit confused.
I think you can get around this, by using True rather than False for the SaveAs option, and then doing a replace in the assembly... at least that would be what I would try.
I hope this helps.
Curtis
oDoc.SaveAs(NewName & ".ipt", True)
Curtis_Waguespack
And just to clarify, I think it would look something more like this, but you'll have to give it a try and see... because I'm making a bit of guess that this is the issue
Dim oOcc = Component.InventorComponent("Bolt 1:1")
Dim oBoltDoc As Document
oBoltDoc = oOcc.Definition.Document
sName = "C:\Temp\NewBolt.ipt"
oBoltDoc.SaveAs(sName, True)
Component.Replace("Bolt 1:1", sName, True)
mark.almack
Yeah that's what i've ended up doing, and it's working more reliably too.
