C# Inventor api HoleFeature Problem
Hi guys,
Here is my c#code
private void button2_Click(object sender, EventArgs e)
Inventor.Application application = (Inventor.Application)System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application");
PartDocument prt = (PartDocument)application.Documents.Add(DocumentTypeEnum.kPartDocumentObject, application.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject), true);
prt.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kMillimeterLengthUnits;
PartComponentDefinition cdef = prt.ComponentDefinition; PlanarSketch sktch = cdef.Sketches.Add(cdef.WorkPlanes["XY Plane"], true); TransientGeometry transgeo = application.TransientGeometry; SketchLine pipe = sktch.SketchLines.AddByTwoPoints(transgeo.CreatePoint2d(0, 0), transgeo.CreatePoint2d(0, 10)); pipe.Centerline = true; SketchEntitiesEnumerator rectanglelines = sktch.SketchLines.AddAsTwoPointRectangle(transgeo.CreatePoint2d(2, 0), transgeo.CreatePoint2d(5, 3)); Profile profile2 = sktch.Profiles.AddForSolid(); RevolveFeature revolve = cdef.Features.RevolveFeatures.AddFull(profile2, pipe, PartFeatureOperationEnum.kJoinOperation); SurfaceBodies bodies = revolve.SurfaceBodies; WorkPlane wp = cdef.WorkPlanes.AddByPlaneAndOffset(bodies[1].Faces[2], 0); PlanarSketch sktch2 = cdef.Sketches.Add(wp, true); SketchPoint point = sktch2.SketchPoints.Add(transgeo.CreatePoint2d(0, 2.5)); sktch2.Shared = true; wp.Shared = true; HoleFeature hf = cdef.Features.HoleFeatures.AddDrilledByThroughAllExtent(point,0.1, PartFeatureExtentDirectionEnum.kPositiveExtentDirection); }
i always get "HRESULT: 0x80004005 "
i think i'm doing exactly same in the İnventors' Hole Exapmles;
Thank You for your help.
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Programming questions for Inventor need to be asked in the Inventor Customization Forum https://forums.autodesk.com/t5/inventor-customization/bd-p/120.   I will have you posting relocated there to better suit your needs.
Mark Lancaster
AlexFielder
Hi @Anonymous,
Comparing your code to the API help page here the only difference I can see is that the sample has the diameter enclosed like this "1cm" whereas yours is just 0.1 without speech marks.
So your code would go from this:
to this:
HoleFeature hf = cdef.Features.HoleFeatures.AddDrilledByThroughAllExtent(point, "0.1", PartFeatureExtentDirectionEnum.kPositiveExtentDirection);
 let me know if this helps.
Alex
Thak you for your reply.
your solution is not correct.
i found the solution
1-Create workpoint on the sketchpoint
2-add workpoint in to the objectcollection
3-create PointHolePlacementDefiniton
4-Object Point =ObjectCollection[1]
5-Use PointHolePlacementDefinition for create hole
Here is my codes
                SketchPoint point = sktch2.SketchPoints.Add(transgeo.CreatePoint2d(0, 3));
                WorkPoint wp1 = cdef.WorkPoints.AddByPoint(point);
ObjectCollection holecenter = application.TransientObjects.CreateObjectCollection(); PointHolePlacementDefinition phpd = cdef.Features.HoleFeatures.CreatePointPlacementDefinition(holecenter[1], cdef.WorkAxes[2]); HoleFeature hf = cdef.Features.HoleFeatures.AddDrilledByThroughAllExtent(phpd,1, PartFeatureExtentDirectionEnum.kPositiveExtentDirection);
it works for me .
AlexFielder
glad you found the solution.
Of course it needed a holedefinition in order to work.
I find it interesting that (in the help) you can use a collection of sketchpoints, but your example using one sketchpoint is insufficient.
