iLogic to Export BOM from Assembly to an excel template
Hi Guys,
I've a folliwing problem to solve.
I have a working iLogic rule which export BOM (properly modified part only view) to an excell file and then starts a macro inside this file.
The rule is checking for purchased parts and skips them and then export data row by row.
All is working quite good but there is one issue I'd like to solve somehow.
I'd like to sort parts in BOM part view first and then export them to excell maintaining proper order.
Below You can see code snippet:
SyntaxEditor Code Snippet
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
UserChoice1 = MessageBox.Show ( "Regu�a generuje Kart� Ci�cia dla Z�o�e�!" & vbLf & "" & vbLf & "Czy chcesz wygenerowa� Kart� Ci�cia dla pojedy�czej cz�ci?", "iLogic",MessageBoxButtons.YesNo)
    If UserChoice1 = vbYes Then
    iLogicVb.RunExternalRule("C:\Users\t.palasz\Desktop\INVENTOR iLOGIC\Karta Ci�cia Cz��.txt")
    Exit Sub
    Else
    Exit Sub
FilePath = ThisDoc.Path
    If FilePath = "" Then
    MessageBox.Show("Plik z�o�enia nie zosta� zapisany!" & vbLf & " " & vbLf & "Zapisz plik, nast�pnie uruchom regu�� ponownie.", "iLogic")
    Exit Sub
UserChoice2 = MessageBox.Show ( "Czy chcesz wygenerowa� Kart� Ci�cia?" & vbLf & " " & vbLf & "Upewnij si� �e wszystkie niezb�dne dane zosta�y uzupe�nione.", "iLogic",MessageBoxButtons.YesNo)
    If UserChoice2 = vbNo Then
    Exit Sub
Dim oAssyDef As AssemblyComponentDefinition
oAssyDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oBOM As BOM
oBOM = oAssyDef.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Tylko cz�ci")
Dim oBOMRow As BOMRow
'Kopiowanie danych zawartych w li�cie BOM do pliku Exel'
GoExcel.Open("C:\Users\t.palasz\Desktop\Karta Ci�cia Wz�r.xlsm","Arkusz2")
i=3
For Each oBOMRow In oBOMView.BOMRows
    If oBOMRow.BOMStructure <> 51973 Then
    NumerPozycji=oBOMRow.ItemNumber
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    FullFileName  = oCompDef.Document.FullFileName
    Pozycja=InStrRev(FullFileName,"\", -1)
    NazwaModelu=Right(FullFileName,Len(FullFileName)-Pozycja)
    NumerCzesci=iProperties.Value(NazwaModelu, "Project", "Part Number")
    Opis=iProperties.Value(NazwaModelu, "Project", "Description")
    Try
    Nazwa=iProperties.Value(NazwaModelu, "Custom", "Nazwa")
    Catch
    End Try
    Try
    Rodzaj=iProperties.Material(NazwaModelu)
    Catch
    End Try
    Try
    Wymiar=iProperties.Value(NazwaModelu, "Custom", "Wymiar")
    Catch
    End Try
    Try
    Uwagi=iProperties.Value(NazwaModelu, "Custom", "Uwagi")
    Catch
    End Try
    Ilosc=oBOMRow.Totalquantity
    GoExcel.CellValue("A" & i)=NumerPozycji
    GoExcel.CellValue("B" & i)=Opis
    GoExcel.CellValue("C" & i)=NumerCzesci
    GoExcel.CellValue("D" & i)=Nazwa
    GoExcel.CellValue("E" & i)=Rodzaj
    GoExcel.CellValue("F" & i)=Wymiar
    GoExcel.CellValue("H" & i)=Uwagi
    GoExcel.CellValue("G" & i)=Ilosc
    i=i+1
Next
    Select Case i
    Case 1 To 12
    Iloscstr = 1
    Case 13 To 24
    Iloscstr = 2
    Case 25 To 36
    Iloscstr = 3
    Case 37 To 48
    Iloscstr = 4
    Case 49 To 60
    Iloscstr = 5
    End Select
    Try
    Artykul = iProperties.Value("Project", "Stock Number")
    Catch
    End Try
    GoExcel.CellValue("A1")=iProperties.Value("Project", "Part Number")
    GoExcel.CellValue("B1")= Iloscstr
    GoExcel.CellValue("A2")= "Art. Nr" & " " & Artykul
    GoExcel.CellValue("D1")=iProperties.Value("Project", "Description")
    GoExcel.DisplayAlerts = False
GoExcel.Save
GoExcel.Close
'Uruchomienie Makra zaimplementowanego w akruszu Excel'
Dim ExApp As Object
        ExApp = CreateObject("Excel.Application")
        ExApp.workbooks.Open ("C:\Users\t.palasz\Desktop\Karta Ci�cia Wz�r.xlsm")
        ExApp.Application.Run ("KartaCieciaWzor")
        ExApp.Visible = False
        ExApp = Nothing
MessageBox.Show("Karta ci�cia zosta�a wygenerowana pomy�lnie", "Gratulacje")
Thanks in Advance for any help
Tomek
mcgyvr
See API/Programming help for
BOMView.Sort
BOMView.Sort Method BOMView.Sort( PrimaryColumnTitle As String, [PrimaryColumnAscending] As Boolean, [SecondaryColumnTitle] As String, [SecondaryColumnAscending] As Boolean, [TertiaryColumnTitle] As String, [TertiaryColumnAscending] As Boolean )
I've tried this. Indeed BOM gets sorted as it should. But then rule starts to export data row by row to the excell file with primary order, it looks it doesn't see that sorting was made. I don't know why.
Regards
Tomek
Curtis_Waguespack
Hi @Anonymous,
Rather than using the GOExcel ilogic functions, try using the API call for exporting the BOMView. This allows you to export the columns in a specified order using the Options variant.
This link has a similar example using the parts list rather than the BOMView:
http://inventortrenches.blogspot.com/2011/06/ilogic-export-parts-list-with-options.html
This links has a BOMView export example, but it is not using options, but again specifying the options would be much like the previous example for parts list:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=BOMView_Export_Sample
Here is the BOMView export API help page:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-C689C910-D089-4CAA-9513-01CB946D1661
Note too that the Inventor Customization forum is likely the better place for questions about iLogic and the programming issues:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Hi Curtis,
Thanks for fast reply and some tips.
Due to part list export - I want to aviod it because I need to export some custom iProperties which I don't want to be visible in the drawing table. Also I'm filling some of those iProperties directly through BOM in the assembly file. So it's much faster to triger the rule directly inside the assembly file instead to oppenning the drawing file.
The reson I don't use an export option is that it takes all parts from the BOM view - I want to exclude purchased parts to avoid manual deleting rows inside an excell file.
If there is a simple way to solve both described problems - I'm open for any ideas.
I'll try to take better attantion to proper post location next time. I'm a rookie right now so I need some time to get use to this forum.
Greetings
Tomek
