Bugs to export PDF format!
If the main window of the Inventor 2014 is hidden or minimized, it will cause jam.
bradeneuropeArthur
Hi @Anonymous
Your problem is: if you minimize inventor the pdf export crashes in 2014 version of inventor?
This is a very old version and there will be not many that can support you on this. You could upgrade to a more recent version like 2019 of inventor!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
